Page 1 of 3 123 LastLast
Results 1 to 12 of 26
Thread: 2.5 vs 3d
    Nov 2009
    2.5 vs 3d
    I hope this is the correct area for this. I am still struggling with the difference between 2.5 and 3d. There is quite a difference in price between the two softwares. I would like to see some pictures of complex 2.5d projects if you have any.
    Most specifically I want to know about Dolphin Partmaster Pro.
    Can hemisphere/dome or convex/dish machining be done with it?
    Do all three axes move simultaneously?
    Please excuse my ignorance, I have no experience with CNC at all, but want to.
    Please don't forget pics!
    Registered M250cnc's Avatar
    Sep 2007
    England
    csaw
    I know how you feel.
    But 2.5D is a shape with a constant Z depth setting for the profile the only exception is when you may have a ramping motion set for the PLUNGE and then it runs X & Y at a constant Z depth
    3D is any shape where all three axis may be moving at once
    Then there will be a step up in price again for 4th axis and even more for 5th axis
    Phil
    Moderator tobyaxis's Avatar
    Jan 2006
    I can't help you with Dolphin but can make references to 2.5D and 3D.
    CAD and CAM are different in the aspects of 2.5D and 3D.
    This is a part created in a 2D CAD environment using various plains, 2D Geometry, with Solids.
    This part will need a 3 Axis Mill to machine it.
    Attached Thumbnails Attached Thumbnails 2.5 vs 3d-mtl-clip.pdf
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jan 2006
    This one is 2.5D and has no need for 3 Axis Machining
    Attached Thumbnails Attached Thumbnails 2.5 vs 3d-shoulder_harness_1.pdf
    Toby D.
    Schwarzwald
    Mar 2003
    Shelby Twp, MI....USA
    Quote Originally Posted by tobyaxis View Post
    That's not helping at all. A 2D CAD program can't do that part. It's created in a 3D CAD modeler. Help the guy, don't confuse him.
    Jan 2006
    Quote Originally Posted by ger21 View Post
    The second post is a 2.5D part. I separated the posts to avoid confusion.
    You have a point with the software being used though. I might be able to find a BobCAD file that is 2D for a better example.
    Toby D.
    Schwarzwald
    Moderator Switcher's Avatar
    Apr 2005
    mydxf.blogspot.com
    Ok,
    2.5D can be done on a 3 or 4-axis machine (X,Y,Z,A)
    3D would be 5-axis or greater (A,C,X,Y,Z), rotary axis both depend on your machine (A,C-axis names).
    It's really all about how you setup the part, you could cut a 3D part with 2.5D software, but when you go to index the part (by hand) you better have a good fixture on your machine to align everything.
    I think your ?'s would be better answered If you post a photo of the part you want to cut.
    Free DXF Files - myDXF.blogspot.com
    Apr 2005
    mydxf.blogspot.com
    How would you cut that part in your .pdf file with less than 3-axis?
    Apr 2005
    mydxf.blogspot.com
    Vectric has a program called Cut3D, that you can use on a 3-axis machine to get very close to 3D.
    Still it's not full 3D (undercuts, etc...), the program only supports 3-axis (X,Y,Z), I understand why they did this, much larger market of machines that are only 3-axis.
    It's still great software.
    Jan 2006
    Here is a reference from the machinery's handbook on 2.5D vs 3D.
    On the left is 3D and on the right 2.5D drawn in an isometric projection.
    Toby D.
    Schwarzwald
    Jan 2006
    Quote Originally Posted by Switcher View Post
    The Reference 2.5D Machining means that you have X,Y, & Z but the Z Axis is only for Depth. A friend of mine has a Proto-Track VMC where the Z-Axis can only be used for depth, hence he can't not do anything requiring Full 3 Axis.
    That shoulder harness was machined using a 2.5D method. There are no Z Feeds in the program, only Z depths
    The differences of 2.5D and 3D can get confusing when asking about both CAD and CAM.
    In CAD you can create a Square Box on a flat 2D plane. Place a Depth Dimension on that same box and machine it. Now you have a 3D Box or Cube.
    No pun intended but your definition wasn't exactly great either, because it is difficult to explain to a person in words. Now if we were all in the same room next to a VMC we could do that in about 2 seconds and show great examples.
    Like I said, it can be difficult to explain.
    Toby D.
    Schwarzwald
    Registered Swag's Avatar
    Jul 2006
    USSA
    Full 3D Yes ProtoTrak
    Toby, A friend of mine has a Prototrak that does full 3 X work, he purchased the DNC key.
    "I'll keep my gun, my ammo, my money, my freedom and you can keep the [COLOR="Red"]"CHANGE"[/COLOR] !
  • Page 1 of 3 123 LastLast
