Results 1 to 10 of 10
Thread: software to convert spline curve to tangent arcs
    Sep 2009
    Is there any CAD package that can automatically covert a spline curve (from DXF file) to a series of a tangent arcs?
    Sep 2008
    Sent you a PM
    Gene
    Dec 2006
    I use Visicam from Vero Intl.
    Edit - curve/polyline to lines/arcs is the command
    select segments, arcs or segments and arc output, maintain tangency checkbox, cordal tolerance option, angular angle option, maximum radius option
    - sound complicated, but I just go "Edit - curve/polyline to lines/arcs"
    select segments and arcs - enter in a tolerance and I'm done - that 3 - 5 seconds
    good luck finding another solution - if you do, let me know
    thanks
    Feb 2010
    israel
    I need the same software myself.
    Is there a freeware that converts spline/ellipse to arcs? (with DXF)
    Sep 2008
    Quote Originally Posted by carbo20 View Post
    Can you post a sample file?
    Gene
    Feb 2010
    israel
    I'm attaching the file.
    it's a simple dxf with spline that i need to convert to arcs in order to use my "OPTOCAD" software .
    Nir
    Attached Files Attached Files
    Mar 2003
    Shelby Twp, MI....USA
    Here you go
    Feb 2010
    israel
    Thank you very much Gery.
    Do you know any freeware that i can use for this work?
    NIr
    Mar 2003
    Sorry, no. But, if you save it as a v12 .dxf, the spline should get converted to short, straight line segments., if that will work for you.
    Feb 2010
    israel
    Thank you Gery.
    It works!
    1. Replies: 5
      Last Post: 09-09-2009, 08:58 AM
    2. Need Help!- Tangent Arcs Mastercam 9.1
      By taa1967sma in forum Mastercam
      Last Post: 03-23-2009, 03:47 PM
    3. Tangent lines joining two arcs
      By yongchiprsnapr in forum Mastercam
      Last Post: 11-30-2008, 05:39 PM
    4. lines-arcs vs spline problem
      By metlcutr55 in forum General CAM Discussion
      Last Post: 07-07-2006, 11:16 AM
    5. Software to follow a spline continuosly
      By fsalla in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 09-22-2005, 08:01 PM
