Use offset face. Otherwise, UG will send you into sketcher because there are no valid sketch curves in the workarea.
Brian
Hello,
I am trying to extrude the face of a solid but UG keeps putting me into the sketcher. I always use this method while making electrodes but a revision change has made this impossible.
Does anyone know how to work around this?
thanks
g,
Brian
I am using the pick menu to select face but it still puts me in the sketcher. I am wondering if it's an error with my environment files. I will try it on someone elses tube here. Currently we have no other UG users in the building due to the "goings-on".
oh..thanks for the reply.
What version of NX are you using?
Set your selection intent to use Face Edges so the edges are selected and not the face.
John Joyce -NC Programming Supervisor
Barnes Aerospace, Windsor CT
I was told to pick edge curve in the command but I can't seem to do that. I have found that if I set the selection menu and pick the element "before" hitting the extrude button works. I still struggle with extruding a face without going into the sketcher.
cheers
