how do you download this?
-James Leonard
I tried to find this plug-in but I couldn't. Basically I just want to convert design into wire frame DXF can be used to convert it to G-Code.
As you know 2D DXF export is not supported by Standard version.
So, I finished initial version the script in a day, today!!!
It seems to be working fine for me. I test some bigger file, it was fine.
Hopefully it can help you. also save your money, too.
You can download from URL below.
http://www.mydiy.pe.kr/technote7/boa...nd=body&no=259
Even its page is Korean, but you can easily find "export_3d_wire_dxf.rb" file around top of the page.
If you have any problem, let me know.
-James Leonard
James Leonard - www.DragonCNC.com - www.LeonardCNCSoftware.com - www.CorelDRAWCadCam.com - www.LeonardMusicalInstruments.com
You can find it with "export_3d_wire_dxf.rb (4KB)" just above the blog title, “ 3D Wire DXF Exporter for Sketchup6 ”. The link has 3.5" diskette icon.
I am still testing and found out that it is not working with very complex component/group design.
I am trying to fix it.![]()
If you don't use Group/Component, it will work fine. I will update as soon as I fix it.
I updated the script and it is now supports Group and Component export.
I tested nested groups and components, it worked fine.
Once you run the script, it will change your design, so press Ctrl-Z or Undo after run the script to roll-back any changes from the script.
