Results 1 to 6 of 6
Thread: how do i put an example title block on a drawing?
    Sep 2008
    i was given an example title block that is "custom" that i need to put on every drawing. i can open it as a normal drawing then i try to save it as a layout and it wont work out right. if you can help that would be great.
    Mar 2003
    Shelby Twp, MI....USA
    What software are you using?
    Sep 2008
    Autocad LT 2008
    Mar 2003
    Are you using layouts and viewports? We place the title block in the layouts, then add vieports in the title block, and add dimensions in paperspace in the layouts.
    What do you mean it won't work out right? Can you be more specific?
    Sep 2008
    i'm fairly new at this but ill try. i need to put our company name and part number onto the drawing in a title block. i have an already existing template but it wasn't drawn on this computer. i'm trying to find a way to somehow either copy and paste it or make it a template so i can use it over and over with many drawings. does that help a little?
    Mar 2003
    Make it a block, and use Attributes to allow you to enter data into the title block.
    1. Need Help!- title block and auto update
      By foxsquirrel in forum Mastercam
      Last Post: 03-20-2008, 09:56 AM
    2. Part->Block->Drawing-> Dimension
      By cncuser1 in forum Solidworks
      Last Post: 11-26-2007, 03:22 PM
    3. Title Block
      By TZ250 in forum Dolphin CADCAM
      Last Post: 07-18-2007, 07:31 AM
    4. Drawing Title
      By sambudy in forum Solidworks
      Last Post: 04-30-2007, 04:15 PM
    5. Angular contact flange block drawing?
      By D.D.Machine in forum General Metal Working Machines
      Last Post: 09-02-2005, 01:14 PM
