Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > General CAD Discussion
General CAD Discussion Discussion for General CAD questions.
Old 06-10-2008, 12:27 AM
Faber.sum is on a distinguished road
Which software to trim .stl files?
Hello everyone
I don't know where would be the perfect place for this post, but I really need help.. so I am posting this on both the CAM and CAD forums. Please forgive.
The question is: which software could I use to be able to trim .stl files with a cutting plane/surface, or to do booleans on .stl meshes?
I have two files to work on, both are .stl and both are too big to be cut on my machinery at once, so I need to cut them in parts.
I tried Meshcad for Rhino but it doesn't seem to work always...
many thanks for any suggestion!
Andrea
Torino, Italy
Old 06-10-2008, 03:16 AM
jalessi's Avatar
jalessi is on a distinguished road
Delcam Millwizard
Andrea,
Take a look at Delcam Millwizard software.
There is a trial download.
http://www.millwizard.com/default.asp
Hope this helps!
Jeff Alessi
Old 06-10-2008, 08:53 AM
Harryman is on a distinguished road
I use Freeform which makes it easy to slice up .stl's, boolean and manipulate. Send me the file and I can do it for you.
www.harryhamilldesigns.com
CAD sculpting and services
Old 06-12-2008, 12:42 PM
Jeff, Harry
many thanks to both of you
I was able to use Rhinocam (Visualmill) to do what I was needing this time - not being able to "cut" the .stl in parts, but being able to work between specified depths then changing my machine Z coordinates for each "layer".
I will try now to download and install Millwizard, and I will look for Freeform too... could you please send me a link where to get some info about this program, Harry?
thanks again
andrea
Which software to trim .stl files? Faber.sum General CAM Discussion 0 06-10-2008 12:24 AM
Free software to measure SolidWorks files? jimmycakes DIY-CNC Router Table Machines 3 05-19-2008 06:04 AM
Software to renumbering G-code files anorec Visual Basic 0 02-01-2007 12:33 PM
scanner software to export dxf files morsee Mechanical Calculations/Engineering Design 2 11-01-2005 10:20 AM
Special trim/moulding software? samualt General CAM Discussion 5 05-26-2004 01:30 PM
