There are many fields of Mechanical Engineering.
There are heating and air conditioning MEs.
There are plumbing and sprinkler MEs.
MEs work as construction administrators, maintenance supervisors, fire marshals and building officials.
A few Mechanical Engineers even design machinery and things that go whir.
It sounds like this is the type of ME that you want to be.
If you become a licensed professional engineer, you will spend most of your time writing and reading. Unless its a small firm, the actual job of drawing and designing parts is usually designated to an engineering technician or
cad designer/operator.
The ME is usually on the business or supervisory end of the system. Someone has to write proposals, write and edit specifications, read codes, read catalog cuts, write control sequences, write contracts, attend meetings, review plans, correct plans, modify plans, modify specifications, write revised proposals, write pay requests, approve pay requests, handle billings, and entertain clients.
Learn to write, learn to read, learn to talk.
If you become a consulting mechanical engineer, your job will be to produce a set of bid documents so that a contractor, supplier, or production shop can come up with a price for an item that is to be produced.
A tremendous number of items are already produced. Usually you will design a product that is made up of other existing products.
Learn to read catalogs, curves, charts and specifications.
While you are reading, learn the codes and regulations. They will be chewing at your heals every minute of the day.
If you just are interested in designing mechanical parts, learn strength of materials, dynamics, geometry, algebra and trig. People in machine design use a lot of trig. It never hurts to know AutoCad intimately. Lots of technician jobs will require an AutoCad test.
A degree in Mechanical Engineering or Mechanical Engineering Technology can lead in many directions. Get a good education in the fundimentals and whatever company that hires you will teach you the specifics.
Hope this helps.
