Page 1 of 2 12 LastLast
Results 1 to 12 of 21
Thread: Engraving on CNC mill.
    Apr 2012
    uk
    Hi im new to this forum so hello to you all!! I was wondering if anyone knows of any free software avalible to generate fanuc code for a conventional milling machine i use in work. Recently a good work friend of mine died in a motorbike accident and ive offered to make a memorial plaque for him out of some brass plate and i want something with fancy letters, not stencil type.
    If anyone can help id really appriecate it. Also im doing this project privately so although the company are letting me use the machine and materials they wont pay for expensive copies of edgecam or other CAD/CAM programs.
    If anyone here has something i could use i could always email the text i want in return for a few beer tokens?
    Cheers
    May 2004
    Then just sketch out what you want and have someone here generate the program for you and then you are done.
    http://www.kirkcon.com/
    Apr 2012
    uk
    Ok thanks...Not sure what format to upload in so ill put up just a basic one and if anyone can help i can send it in autocad format or something similar.
    Apr 2012
    uk
    This is roughly what i want....The brass billet is 250mm x 140mm and the font size i used on autocad was 20, the text was "palatino linotype" but my version of autocad has limited options...
    Apr 2012
    uk
    I am happy programming and using macros if thats an option when generating a program....What tooling would be required i have done little engraving work before i was thinking a ballnose or maybe just a standard 90degree spot drill or similar?
    Mar 2003
    Shelby Twp, MI....USA
    Free engraving software: NCPlot - Stick Font
    Apr 2012
    uk
    Quote Originally Posted by ger21 View Post
    Cheers for the link but i dont think it will work for what i want..Cant seem to get the words on differnt lines. That software will come in handy though! Is the x location and y location the datum position?
    Registered LouF's Avatar
    Sep 2011
    http://www.cnczone.com/forums/diy-cnc_router_table_machines/140832-new_fla-100_kit_build.html
    May 2008
    uk
    Try the attached file to see if it's something like what you're after.
    You'd need a 90deg conical cutter with a 0.2mm flat tip for it to cut correctly as it's a V-Carve type of toolpath.
    Martin.
    Attached Files Attached Files
    Apr 2012
    uk
    Thats just what i wanted mate cheers...Ill give it a dry run tomorrow on the machine and let u know how i get on..Thanks..Ill get a pic uploaded of the finished article..What did u use to generate that code?
    May 2008
    uk
    I did it with Ucancam.
    Do check the feeds and spindle speed before you use it in earnest because I've left everything at its default setting and I've found some of these to be a little optimistic. Also note that the maximum cut depth is ~ 2.25mm so you might need to take things steady.
    Martin.
    May 2008
    uk
    Another version with BOLD text turned off.
    Martin.
  • Page 1 of 2 12 LastLast
    1. Engraving using Haas mill
      By laurencen in forum Haas Mills
      Last Post: 04-25-2011, 06:43 PM
    2. Engraving on CNC mill
      By HexkeyCNC in forum Australia, New Zealand Club house
      Last Post: 06-05-2009, 05:27 AM
    3. Taig CNC Mill Engraving ?
      By gunlocators in forum Taig Mills & Lathes
      Last Post: 02-14-2009, 12:41 PM
    4. Need Help!- New engraving with CNC mill
      By bherr in forum Engraving Machines
      Last Post: 02-05-2008, 08:47 AM
    5. Using CNC Mill for Engraving
      By studysession in forum General Metal Working Machines
      Last Post: 10-22-2006, 10:15 PM
