If you have the option, try saving it as a .v12 dxf, which doesn't support splines.
Hello,
I have a.pdf file that I need to convert to geometry for a water jet to use. I have Solidworks MasterCam AutoCAd and Esprit.. Solidworks will open a .pdf after I save it as a .ai with adobe illustrator... But when I save it as a .dxf in SolidWorks it makes splines out of the arcs... Is there a trick to this?
Hi, could someone please convert this image to a DXF file please as i do not have the necessary software.
Thanks in advance
