Page 1 of 2 12 LastLast
Results 1 to 12 of 23
Thread: What software Y'all using?
    Mar 2012
    OK, i don't have a $1000 to throw at software. I've been using emachineshop for 2D drawings that are good enough for the waterjet guy. What I have are some 3D pieces that need to be turned, and I can create them on emachine, but the output file is not good enough for them to look at.
    Thanks,
    CR
    May 2004
    For turning, you still only need 2D to draw the profile of the part.
    http://www.kirkcon.com/
    Mar 2012
    Drawing isn't the problem, it's the machine shop looking at the part and getting dimensions from it. The 2D DXF file I sent them didn't look so hot, and they couldn't import a IGS file either.
    May 2004
    While 3D and solid models make the designer's job easier, they do not replace 2D orthographic projection drawings. To get a tool path for a lathe on all the CAM software I know of, all one needs is the 2D profile. If your shop is having trouble visualizing the finished part, sending a graphic, just like you did here is an acceptable way to relate that information. You already indicated your lack of funds to purchase software. The cheapest software I could recommend is free for 2D and minimum of over $2000 for 3D. So, there you have it. See if someone else can offer a better cheaper software. Or, come up with more money.
    Take a look at some of these:
    http://www.freebyte.com/cad/cad.htm
    Jan 2008
    You can rent Ashlar Vellum programs by the month. Thats what I did until I could afford a purchase (and I did NOT purchase Ashlar Vellum).
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    http://microcarve.microcarve.biz/
    Mar 2012
    Quote Originally Posted by dertsap View Post
    Dude, I just watched the video, that's the stuff!!! Looks like I could even import the 2D's that I have and export them to ACAD files...
    CR
    Oct 2005
    canada
    Quote Originally Posted by ny_racer_xxx View Post
    CR
    you can download a demo to give it a try , its very functional for what its worth and its worked great for anything that I've used it for so far .
    as it is with anything it takes some time to get used to it
    Mar 2012
    I didn't see any direct link to a download or demo area on their site so I googled it and found it. You have to fill out a questioner, and they email you the link. It took the better part of an hour to download!!!
    It's the V7 version, I guess close enough...
    CR
    Oct 2005
    canada
    an hour and a stupid questionnaire sounds like a pita
    i don't think there is much difference between versions other than the odd bug fix or what not , i still use version 6 which seems fine ,
    Registered BurrMan's Avatar
    Dec 2008
    Punch makes a very capable product...
    Questionare??? Name-email address and a comment.
    PunchCad Labs
    The download is something like 500+ mb... I guess that speed will vary for different users.
    The download links to demos, does only include the 2d/3d version 7 and the pro version 7.
    The 2d/3d has been updated to version 8 and has some enhancments... It's only "$99.00"... It will do good solid modeling.. The pro version, $249 will add more advanced surfacing tools and rendering stuff and a multiple viewport.
    Mar 2012
    I tried it last night after it finished the download.... The import export features seem pretty good and that might be worth the price of admission right there...
    I saw upgrades from older to newer versions, I didn't see upgrade from 2d/3d to pro, that would be nice...
    CR
  • Page 1 of 2 12 LastLast
    1. Newbie- Need software advice...What software can import .JPG files?
      By pairofjacks in forum General CAM Discussion
      Last Post: 06-01-2011, 07:18 AM
    2. Build Thread- machine control software & cam software
      By grttt3 in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 05-06-2010, 02:49 PM
    3. Just IN- MIE Solutions - Free Quoting Software Trial Software available
      By MIE Solutions in forum Product and Manufacturer Announcements
      Last Post: 01-07-2009, 11:42 AM
    4. First post in the software dept. Free cnc software?
      By runinbymdnt in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 02-06-2007, 10:49 PM
