Results 1 to 3 of 3
Thread: Cad Pockets
    Dec 2011
    Cad Pockets
    Ok I am new to the cnc field but have been doing cad drafting for a while. Here is the question, when you want to do a recessed area how do you get the tool paths to remove that area? The only way I can figure out is to draw lines in the area that area spaced the tool diameter apart. Any help?
    I am using AutoCAD and Mach3.
    Warren
    Mar 2003
    Shelby Twp, MI....USA
    The easiest way is to use a CAM program that does pocketing.
    You can also do it by drawing lines, or offsetting inward. Space the lines less than the tool diameter, usually 50-75%, depending on the material you're cutting. You can also hatch the area and explode the hatch.
    Dec 2011
    That's what I thought. Thanks
  1. Cut 2D Z retract in pockets...
    By kiwichris in forum Vectric
    Last Post: 08-15-2011, 09:15 PM
  2. Deep pockets
    By AirAce in forum General Metal Working Machines
    Last Post: 05-08-2011, 02:03 PM
  3. Deep Pockets
    By BlueFin in forum Tormach Personal CNC Mill
    Last Post: 03-20-2011, 01:42 AM
  4. Problem- Pockets and Islands -
    By 2Bits in forum Dolphin CADCAM
    Last Post: 04-23-2009, 10:35 PM
  5. pockets
    By raymond1 in forum Haas Visual Quick Code
    Last Post: 05-20-2007, 07:59 AM
