Results 1 to 6 of 6
Thread: Need help with dxf generation
    Nov 2010
    Netherlands
    I'm building my website / application where users can upload and/or customize existing drawings to fit their own needs and dimensions. It all worked with SVG, but now I'm working on a DXF export, so I can send drawings to cnc routers. I do have one program (viacad) which is showing my dxf drawings correctly. However I did send a few of my drawings to a cnc / carpenter shop who could not read my generated (attached boomerang.dxf) file with autocad 2010 ( internal error: !dbr12dxfin.cpp@2318 ) after which autocad crashed and tried to send a report to autodesk. I'd really appreciate if somebody could give me hints on what's wrong. You can experiment yourself with my online dxf generation tool select DXF (You need a modern non IE browser, firefox v10 or chrome v16 are just fine) and provide feedback on the generated dxf.
    Attached Files Attached Files
    Mar 2003
    Shelby Twp, MI....USA
    I can't get it to generate a .dxf file. I want to make something simple to compare to a good .dxf.
    Dec 2003
    AutoCad also show a DXF file error if trying to load the DXF file, however DXF to DWG convertor works OK and it displays as a DWG drawing OK?.
    Nov 2010
    Netherlands
    I went back to the original python package (dxfwrite), from which I basically borrowed the logic. DXFwrite is supposed to generate R12 DXF.
    Attached 2 files which come directly from dxf write.
    Dec 2003
    At least AutoCad opens these OK.
    Nov 2010
    Netherlands
    Talking
    Thanks, so DXFWrite was okay and i skinned its output too much. I'll proceed to incorporate this in my generation tool.
    Thanks again
    1. New Generation VMC spindles
      By gpettit in forum Haas Mills
      Last Post: 02-07-2012, 01:50 PM
    2. electric generation
      By screenzzzz in forum General Electronics Discussion
      Last Post: 03-12-2009, 07:49 AM
    3. Need Help!- NX4 toolpath generation
      By thirumalkumarn in forum General CAM Discussion
      Last Post: 05-27-2008, 08:47 AM
    4. How to generation toolpath ?
      By havythoai in forum Coding
      Last Post: 03-18-2008, 10:47 AM
    5. G Code Generation
      By robbycar in forum General Metal Working Machines
      Last Post: 05-20-2004, 08:10 AM
