Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: AutoCAD 2012 grid question
    Oct 2011
    I am looking to create a grid that is 10"x10" and has .25" spacing for a project I am doing with my students. We have been using a very old CAD software program and I am not entirely used to 2012 yet. I only want students to see a 10"x10" area to draw in. I found where to change grid spacing but I haven't figured out the other half. Thanks for your help!
    Mar 2003
    Shelby Twp, MI....USA
    Look up the LIMITS command in the help file. The grid will still be infinite, but you can only draw in the specified area. You might want to draw a border on a special layer and lock it, so it's easier to see the extent of the limits.
    Oct 2011
    Thanks for your help. It worked perfect! My next question is I am looking to join the corners of overlapping rectangles in 2D. When I used AutoSketch8 I used to use the union tool to do this but it doesn't seem to work the same in AutoCAD 2012. I've attached a screenshot of what I got. Thanks again!
    Attached Thumbnails Attached Thumbnails AutoCAD 2012 grid question-cad_box.jpg
    Mar 2003
    I don't understand what you want to do?
    Oct 2011
    I used the rectangle tool to draw four different rectangles with the ends overlapping. I now want to "join" the corners and have it so you see a square inside of the outside square without the corners intersecting. I've attached a screenshot showing what it would look like after using the command. I have to draw separate rectangles for a reason and then join the corners based on a CNC machining process or I would not be trying to do it this way. Thank you again!
    Attached Thumbnails Attached Thumbnails AutoCAD 2012 grid question-cad_box2.jpg
    Mar 2003
    So you want to "center" the smaller one inside the larger? I don't believe there's a command to do that.
    What I've always done, is draw a line from corner to corner in each rectangle, and then move one, using the midpoint of one diagonal to the midpoint of the other.
    Mar 2003
    OK, Google just found a quicker way.
    Draw your 2 rectangles.
    Select one and use the Move command. (I right click to access the command)
    Shift-Right Click, and choose "Mid Between 2 points", and pick diagonal corners of the rectangle.
    Shift-Right Click again, and choose "Mid Between 2 points", and pick diagonal corners
    of the destination rectangle, and it will be centered.
    I'm not sure why you can't just use the offset command?
    In your example, nothing is actually "joined"? If you can you explain exactly what you're doing a little better, I might have a better solution.
    Oct 2011
    My middle school students construct a marble maze project using our CNC machine. I have them draw .25" thick rectangles within their 10"x10" grid to act as walls. Our CNC machine then uses a .25" end mill bit to mill out grooves for their walls .125" deep wherever they have rectangles. We create a tool path so that the end mill bit stays in the center of each rectangle.
    In the past when students draw in all of their rectangles in CAD, I have had them overlap the ends by .25" so that they could go back and union/join their rectangles. This way the CNC machine will mill out their walls continuously and not start and stop on each wall.
    Attached Thumbnails Attached Thumbnails AutoCAD 2012 grid question-autosketch_example.jpg   AutoCAD 2012 grid question-img_2664.jpg
    Mar 2003
    I think you'll need to teach them how to move them and use the trim command, and if you need all the lines joined, use PEDIT with the Join option.
    Oct 2011
    Thank you for all of your help. It seems odd to me that AutoSketch would have a feature to "union" that AutoCAD does not in 2D. I'll try to see what I can do with my students here and if we are able to make that work. Thanks again.
    Mar 2003
    I'm still not sure if I understand what you want to do.
    The Union command does work in 2D, if you convert your rectangles to regions first. (Just type REGION, and select them).
    This is the result of the union command.
    Attached Thumbnails Attached Thumbnails AutoCAD 2012 grid question-union.jpg
    Apr 2006
    To do what you want, you must understand that the rectangle command draws what acad calls a polyline. It draws a closed polyline to be specific.
    So to remove portions of a pline, you should trim them out. then you will have separate pieces that you can join with the pedit command.
    Not sure if you care if the end result is a pline. if not, just explode the plines and then you have simple lines that are esy to manipulate.
  • Page 1 of 2 12 LastLast
    1. Free AutoCAD 2012
      By DroopyPawn in forum Autodesk Software (Autocad, Inventor etc)
      Last Post: 07-28-2011, 05:37 PM
    2. AutoCAD 2012 tutorial
      By bmx4637 in forum Autodesk Software (Autocad, Inventor etc)
      Last Post: 07-24-2011, 07:55 PM
    3. Proge Grid question
      By ImanCarrot in forum ProgeCAD
      Last Post: 03-23-2010, 09:31 AM
    4. Noob Drill Grid Pattern Macro Question
      By KOzOK in forum Fadal
      Last Post: 01-08-2007, 10:11 AM
    5. Autocad question
      By rocketguy in forum Autodesk Software (Autocad, Inventor etc)
      Last Post: 02-17-2004, 08:23 PM
