Hi There,
sorry to hear of your problems... but it seems you do have something to export.. which is good news...
Extract the file 'exportmd3.dle from the attached zip.. and put it in your gmax\plugins directory..
When you go to export... if it doesn't show .md3 by default.. select it from the dropdown... just below where you'd type the file name on the file panel... It should then use this as your usual export option...
the plugin should come with gmax... but here it is anyway..
Hope this helps
Danny
LinkBack URL
About LinkBacks
