What software are you drawing with?
Hi
At times my drawings which I save as a DXF file turns up in Lazycam with alot of chains and entities which causes the Z axis to work unneccessary and the cutting takes extra long.
Is there software available to join all the lines and circles to form one continous line.
The drawings I do is simple stick drawings and use Lazycam to generate Gcode in conjunction with Mach 3.
Thank you
Gasant
I am using Cadstd and I have tried other cad software but the results seem to be the same.
Gasant
