Results 1 to 2 of 2
Thread: cone calculator
    Dec 2007
    cone calculator
    i need to cut a series of cones on a plasma table . it uses desk cnc.
    i would like to find a cone calculator that will put out g code, or at least put out in a form that desk cnc will turn into g code (stl, dxf or what ever)
    Registered tulsaturbo's Avatar
    Feb 2008
    http://www.pulserate.com
    Cone Layout is a program to unfold a frustum of a cone and generate a sheet cutting layout or flat pattern projection that can be rolled or bend up into a truncated cone shape. Either side of the truncated cone can be tilted. To help you visualise the cone you are editing, a rotating 3D model shows the dimensions.
    The layout pattern can be printed directly on paper for use as a template for cutting out the shape from a plate of metal. Or you can write the layout pattern to an AutoCADŽ DXF file which is the world standard among computer controlled cutters. Other supported file formats are Encapsulated PostScript (EPS) or a plain text file with coordinates.
  1. Internal cone operation
    By pinguS in forum SolidCam
    Last Post: 02-21-2011, 03:19 PM
  2. Cone Cutting in 15 mm mdf
    By SuYoG in forum FAQ of CNC Machine building
    Last Post: 12-16-2010, 04:54 PM
  3. Text on cone.
    By KVD in forum GibbsCAM
    Last Post: 05-27-2010, 10:50 AM
  4. Need Help!- Flattening out a cone ???
    By Mr. LocoMartin in forum BobCad-Cam
    Last Post: 04-09-2009, 10:04 PM
  5. I need help milling a cone!
    By dynoman in forum CNCzone Club House
    Last Post: 01-21-2009, 03:56 PM
