Results 1 to 3 of 3
Thread: How would you tool path this...
    May 2005
    I have a Techno Isel 4896 Servo Router.
    I rely almost exclusively on Vectric's Aspire program for my G-Code generation.
    I have an opportunity to process a lot of panels that need a bull nose profile.
    How would you tool path the profile, so that the z-level is accurate and the depth of cut does not hog too deep into the panels profile, after touching off?
    Any help would be appreciated.
    D
    Attached Thumbnails Attached Thumbnails How would you tool path this...-bull_nose_question.png
    Registered BobWarfield's Avatar
    May 2005
    Use a 2D profile on a path that is the correct distance from the edge of the panel to get the desired bullnose?
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Mar 2003
    Shelby Twp, MI....USA
    If the panels are all the same, make a dedicated vacuum fixture the full size of the panel, to support it. If not supported near the edge, you're depth will vary.
  1. No tool path?
    By spincaster in forum Rhinocam
    Last Post: 04-06-2010, 10:37 PM
  2. Newbie- Which Tool Path ?
    By weirdharold in forum UG NX
    Last Post: 11-24-2009, 12:07 PM
  3. Need Help!- can't get the tool path right
    By msn_jrd in forum Mastercam
    Last Post: 07-21-2008, 11:43 AM
  4. 3-D TOOL PATH
    By reedmiles in forum BobCad-Cam
    Last Post: 02-02-2008, 08:08 PM
  5. Tool approach Tool Path
    By Kiwi in forum BobCad-Cam
    Last Post: 07-05-2007, 03:35 AM
