Results 1 to 3 of 3
Thread: Need tubing software!
    Apr 2010
    Hello,
    I have been searching for a tubing software that can help process bent tubes. Currently we are using Autodesk Inventor to do our design work. And we send our models to ArtTube before the parts go to the tube laser. The problem is that ArtTube will only take straight runs of tubing. Any part with a bend has to be drawn out in a straight run, and this gets very time consuming with more complicated tubes. The saddles have to be redrawn also. So, I am needing software to take a bent tube, and flatten it out before it gets sent to ArtTube, and ArtTube needs a step file for the best translation.
    ANY help would be greatly appreciated. Thanks,
    Matt
    Apr 2010
    Correction to post
    The program is ArcTube, not ArtTube...
    May 2007
    Have you seen www.bend-tech.com?
  1. 5/32 copper tubing
    By dgalaxy in forum Bridgeport and Hardinge Mills
    Last Post: 06-19-2010, 09:24 AM
  2. PEX hose/ Tubing?
    By fretsman in forum Work Fixtures and Hold-Down Solutions
    Last Post: 06-19-2008, 04:58 PM
  3. Drilling in tubing
    By tz1238 in forum SolidCam
    Last Post: 12-12-2007, 06:47 AM
  4. tubing notcher
    By stanglou in forum General Metal Working Machines
    Last Post: 02-12-2007, 12:47 AM
  5. RFQ: Tubing bending
    By Msport in forum Employment Opportunity
    Last Post: 01-19-2007, 11:27 PM
