Page 3 of 4 FirstFirst 1234 LastLast
Results 25 to 36 of 46
Thread: Scam or not selling machine
  1. #25
    Feb 2005
    Hi little bubba
    The check that you had deposited had not been cleared by your bank if you ask your bank they will tell you so you payed your credit card with money you thought you had,
    (2) You did not check with the bank to see if the check had cleared as I said in other replys here it does not matter where the check comes from its not yours to spend untill your bank has cleared it & you have to verifiy this with your bank if it is a large amount that you need to use
    (3) Now if the bank messed up & some how lost your deposit then this would be there fault & you would not have any late or over draw fee Etc they the bank is the libel party here if this is the case you should be claiming it all back from your banker
    (4) A International check is the same as any the money is not in your account
    untill your bank has cleared the check no matter how long it takes its not there to spend untill you have verified it with your bank
    I had something like this happen to me one time some years ago & the bank payed all the fees back plus payed the credit card extra fee so banks if they are wrong they will make it right for you just get in there face a little if you are right & they the bank will fix it for you
    I got back almost all of the fees, and I was in the wrong for not checking and banking at the Bank of WeSuckGiantMonkeyBallsandWillScrewYou.
    What I was referring to was the Bank of LostDepositsandGovernmentTakeOversThatSucksGiantMonkeyBalls was able to pull back a check from CitiBank that had already cleared. There is no way in this world that Citibank is going to post a credit to my account and not charge me interest on money that they do not physically(in the cyber world)have.
    What I'm saying is that even after a check has completely cleared, it can still get yanked back. The funds had already been moved from the Bank of WeSuck to Citibank, they were at Citibank for 11 days, I didn't pay interest on that money for 11 days, they actually probably had it for 14, but you know how credit cards are. The fact that I didn't(even though I actually did) have enough money has no bearing, the Bank of WeSuck had the power to go in and suck back a cleared check.
    Now take this same scenario and move half of it overseas, into a country with a whole lot more corruption, if thats possible. Nasty things can happen.
  2. #26
    ckm
    ckm is offline
    Too many projects
    Jun 2006
    Hi little bubba
    Actually, this is completely wrong. Ask your bank sometime if they can tell you how long it takes a check to clear. The answer is YOUR bank clears it in 2 days for a local bank, 5 days for an outstate bank and overnight if it's something official (gov't, cashiers, etc). This process is actually Federal law.
    HOWEVER, and this is the big scam no one will tell you about, it may take the ISSUING bank 4-6 weeks to confirm the funds are available and that the check is legitimate. Normally this is not a big deal, but if it's a fake, the whole transaction unravels EVEN IF YOUR BANK SAYS IT CLEARED. And you are responsible for the whole amount.
    From the FTC itself:
    "Under federal law, banks must make funds available to you from U.S. Treasury checks, official bank checks (cashier’s checks, certified checks, and teller’s checks), and checks paid by government agencies at the opening of business the day after you deposit the check. For other checks, banks must similarly make the first $100 available the day after you deposit the check. Remaining funds must be made available on the second day after the deposit if payable by a local bank, and within five days if drawn on distant banks. However, just because funds are available on a check you’ve deposited doesn’t mean the check is good. It’s best not to rely on money from any type of check (cashier, business or personal check, or money order) unless you know and trust the person you’re dealing with or, better yet — until the bank confirms that the check has cleared. Forgeries can take weeks to be discovered and untangled.
    The bottom line is that until the bank confirms that the funds from the check have been deposited into your account, you are responsible for any funds you withdraw against that check."
    http://www.ftc.gov/bcp/edu/pubs/cons...dit/cre40.shtm
    Bottom line is that, even if the funds are cleared, they can still be withdrawn if the check is eventually found to be bogus, even if that is months later. And, BTW, notice the contradictions within the FTC's own description (cleared vs deposited vs funds available), that's what scammers exploit and most bank employees won't be able to tell you what state your deposit is actually in...
    For really small amounts (under $2000), PayPal is a pretty good (if expensive - use this http://ppcalc.com/ to recover the fees) way to get foreign payments. If it's more than that, you can do a SWIFT transfer, which is a standard way of moving money internationally. For significant transactions, the standard way is Letters of Credit and escrow accounts, but that's only worth it over $100k.
    Chris.
    List of parts sources for CNC builders - http://www.CNCsources.net
    Dyna Mechtronics 4400C Conversion - CNC bed mill w/toolchanger to Mach3 conversion - http://www.cnczone.com/forums/showthread.php?t=50787
  3. #27
    Jan 2005
    Scam or not
    I have noitced one thing that is more important than anything else is that nobody so far
    have looked at one thing
    What was a guy in the UK going to do with a Hyertherm Max 200 it would be no good to him if it did not have the right power requirments which was the first thing that I saw was wrong the UK mostly being 400v 3ph & there 1ph Which is 230v hot per leg so unless this Hyertherm has multiple voltage inputs it would be of no use to the buyer in the UK
    Mactec54
  4. #28
    *Registered User*
    Apr 2008
    SCAMS
    Are only sucessful & happen when the other party has your bank information THAT MEANS YOU MAKE IT HAPPEN
    DO not allow wire transfers as they will have your bank account & bank routing Numbers
    Get only Bank certified checks sent to you by certified mail once you request this you will know whether if they are a scammer or not as you will not hear from them again.
    Check with the bank to see if the check has cleared & NOT PENDING before you go SPENDING
    IF the Bank does not clear the check in your account they the bank will remove it FROM YOUR ACCOUNT NOT THE OTHER PARTY
    There are other things that could be added to this but this is the main stuff
    Kirkln you said that the guy emailed you before you placed the add that you had your machine for sale How would he know this without information from you about your machine That is not possible to gess what you had for sale without you telling him
    I thaught I said he contacted me because it is advertised on this site this is the only place I have it listed so he must have seen it here
  • #29
    Registered ImanCarrot's Avatar
    Nov 2005
    UK
    And he dun speak proper English like what we does.
    I would bet my firstborn that it's a 100% scam.
    He'll send you a cheque and, as previously posted, send you too much then ask for a refund minus a deduction.
    There's whole sites dedicated to wasting these scammers' time. Some have even managed to string a scammer along for months wasting their time and getting them to travel miles to pick up the cash ("I'm going through a divorce and my account is frozen.. can I pay you cash?"). My favourite was one anti-scammer who got pictures off a live cam of some crossroads in like Amsterdam or something and sent the scammer a picture of where he would meet him with the bag of cash. He then posted the scammer turning up. Top bannana. Pure class
    I love deadlines- I like the whooshing sound they make as they fly by.
  • #30
    *Registered User*
    Apr 2008
    UK voltage
    I have a 200 ton press brake that was made in Russia I have 230 3 phase at my shop it was wired 440 in the shop I bought it from here in Mich. I wired it to 230 3 phase and had to use a large reostat the control voltage was 38 the 3 phase in UK is 380 I don't know if our 3 phase equipment would work on 380 or not my guess is (no) it would be to low but you could buck the voltage not easy though
  • #31
    *Registered User*
    Apr 2008
    Refund
    He did I gave him my address after reading the posts on here made sense to me he can not get my bank info here is his reply LMAO
    ATTENTION: Kirk Michigan welding
    I APPRECIATE YOUR PROMPT RESPOSNE AND I MUST SAY THAT I AM VERY HAPPY AT THE INFORNATION YOU PROVIDED.
    IN NO TIME,I WILL START WITH THE MAILING OF THE CHEQUE TO YOUR CONTACT ADDRESS,AND I EXPECT YOU TO BE ON THE LOOK OUT OF IT.AS SOON AS YOU HAVE THE CHEQUE AT YOUR CONTACT ADDRESS,MAK SURE YOU PROCEED TO THE BANK FOR IT TO BE CLEARED.
    AFTER IT MUST HAVE BEEN CLEARED, YOU WILL DEDUCT THE PRICE OF THE ITEM AND SEND TO MY AGENT THE EXCESS AMOUNT FOR HIM TO START THE PROCESS OF THE PICKUP OF THE ITEM.
    HOPE TO HEAR FROM YOU SOON.
    REGARD,
    WAYNE STANLEY
  • #32
    Gold Member lovebugjunkie's Avatar
    Apr 2005
    Chris
    Your post brought back memories of SWIFT. You are right, SWIFT is a very secure, fast and reliable way to transfer funds worldwide and in country. SWIFT can get your transfer from point A to B in seconds; it’s the beginning and end points (banks) you have to worry about. I could relate a few stories about transmitting and receiving banks in the SWIFT system that would make you want to remove your money and never trust a bank again.
    I worked for SWIFT many years ago, had a few positions in the Culpeper Va facility, in the computer operations and network control sections. Very interesting positions, one thing I found out about banks that surprised me was how often they make mistakes in accounting for money in a timely fashion.
    I think some people give banks way too much credit for doing things by the book.
  • #33
    Jun 2008
    Uk
    This is a classic 419 type scam.
    Have a look at the 419 eater site if you doubt it. Not only is the guy most probably in Nigeria and not the UK, they are serious,serious people, not someone you want to be messing with. The 419 eater crew bait these scammers and some of the lengths these people will go to to get your money/item is amazing and can be hilarious and in the case of one scam documented on the site, the scammers sending people to Glasgow from London to collect money for a scammer controlling them from Nigeria, very worrying.
    I forget actual figures but it is in the millions of dollars these criminals scam out of US citizens alone every year, some actually go over to Nigeria etc to confront these people and come home in a box, luckier ones just lose their life savings or CNC machines ;-).
    If you get one of these approaches, IGNORE IT. Don't reply, especially with any personal info, even names and addresses can be used to steal your identity. I know from personal experience.
    Regards, Jeff.
  • #34
    Jan 2005
    Smiler
    smiler you are right it sure is a scam the last email tells it all when you get the check kirkln give it to the Feds & let them get this scum bag.
    Mactec54
  • #35
    Jan 2005
    In the interest of safety, you should can the idea of any contact with this person . How can you know if I would put a back door trojan program into your e-mail and suck out all your info. Or, maybe he has already done that. Sell the machine in the USA. I can see no reason why he would want to buy your machine and ship it to Britain. It probably would be hit with an import tax besides the cost of shipping. Then add cost of dealing with voltage change. Come on! Besides, he states that he is an American living in Britain. Why would he use British spelling to converse with an American. The sentence structure looks just like the letters sent from Nigeria that cheat thousands of people at a time.
  • #36
    Apr 2007
    The safest way I know of to deal with an international transaction is an irrevocable letter of credit, opened with a major bank. (example, bank of america, citibank, etc, not joe local bank of malaysia)
    As I understand it, the only way a MAJOR bank will issue an LC, is that the payer must put the money into an account that only the bank controls - cash. The release of the money to you needs to be agreed upon based on some aspects, such as a bill of ladding. Once you present the bill of ladding to the bank (hopefully, one you use), they will release the funds to you.
    AFAIK, it this prevents the parties from having direct access to your own personal banking info, and cannot be back tracked / reversed. This is a common used transaction method for doing business in the Far East, where payments can be a bit "challenging".
    It is not cheap to do an LC, but they are pretty solid transaction methods.
    If someone is not willing to do an LC, they are not legit. Most scams will go away the moment you ask for an LC from a MAJOR Bank with International experience. Once again, the fees can be significant, but my son learned the hard way that he should have used an LC on a transaction instead of a wire transfer. (he lost his entire payment to a seller in Indonesia, almost as scam driven as Nigeria)
  • Page 3 of 4 FirstFirst 1234 LastLast
    1. Anyone In Ontario Selling a Homemade CNC machine
      By Big_Lunn in forum Canadian Club House
      Last Post: 10-27-2008, 10:34 AM
    2. **SELLING MY MACHINE on ebay 99cents start price**
      By ynneb in forum Australia, New Zealand Club house
      Last Post: 10-28-2006, 11:00 PM
    3. PayPal Scam Alert
      By ToyMaker in forum CNCzone Club House
      Last Post: 07-18-2003, 10:50 AM
