Hi all, first post here so be gentle! ![]() I want to get a quote on some work but before I can ask for one I need some information on waht is required: At the moment i Sketchup plans for the parts for a model building that take up, roughly two A3 sheets in surface area. Should the parts be left as individual parts (for the CNC person to arrange) or should I try to frame them into a sheet? If i should be putting them on a frame what spaces do i leave between parts? What is the best format for the images - .dxf .jpg.. Sketchup-Pro is capable of quite a few file formats.... is the 3D dimensionality of them of any use or hinderence? Should they be flattened into 2D images? I think that's all my questions, replies and any advice on additional information needed for posting a RFQ appreciated. |
| I would think that 2D dxf or dwg for importing into a CAM system to allow entry to the quoter's machine A 3D image could be included for illustration purposes, usually the successful quoter will have the necessary software for nesting etc and be aware of required spacing. Al.
dumb question probably .. but.. does the pdf need to ahve the dimensions on every part... or is it purely to get a handle on the shapes ? |
| Dimensions are critical and tolerances on the dimensions too. You're from the UK, be aware that Americans will assume inches and us brits will assume mm so specify it in black and white...1+/-0.1 could mean anything from Acres to Angstroms. [Edit]Sorry what I meant was it'll be cheaper with lose tolerances than tight ones. The amount of jobs I've done where I've spend time (money) hitting a particular tolerance only for the customer to later say "Oh we didn't really need it +/-0.005mm".[/Edit]
__________________ I love deadlines- I like the whooshing sound they make as they fly by. Last edited by ImanCarrot; 09-29-2010 at 09:51 AM. |
| aluminium cnc quote required | crimsonred | Employment Opportunity | 5 | 09-30-2010 11:15 AM |
| Need a quote | hoale33 | Employment Opportunity | 1 | 05-02-2009 11:22 AM |
| G320/G340 'Required Direction Setup' and 'Required Direction Hold' times? | margni74 | Gecko Drives | 2 | 12-05-2008 08:10 PM |
| Quote required for rotary laser work request | OldBob13 | Australia, New Zealand Club house | 0 | 07-02-2008 06:14 PM |
| Quote and Multi-Quote | JoBwan | Test Forum | 0 | 02-23-2008 05:58 AM |
