Results 1 to 8 of 8
Thread: I can haz 3D printer too?
    Oct 2010
    Let us start yet another one. So many people posting theirs that after so long of seeing them on youtube and thinking how cool they are I am going to break down and do it. To start off with this I am going with the Prusa. I have made up a list of everything I should need. Been selling off some stuff on the internet to raise some funds to help the build that way my wife doesn't grouch about spending the money lol.
    My list brings the total right now to around $700. Let me know your thoughts and anything I am currently forgetting(except spools of material) or anything better I should get instead or a better place to get it.
    Component Price
    Linear Prusa V2 Kit with Z stabilizers $195.95
    J-Head Mk IV-B Hot End with Install Kit $78.95
    Mk1 Heatbed with Install Kit $47.95
    Shipping from Makerfarm $35.60
    100k Thermistor $2.75
    RAMPS Pre-Assembled Kit Complete-shipped $207.35
    12V 30A 350W power supply $35.99
    NEMA17 motors qty5 $43.45
    Threaded Rod- Metric 8.8 M8 @ 1 Meter per piece x6 $25.74
    Smooth Rod- O1 drill rod M8 @ 3 Feet per piece x3 $15.39
    Gold Member hoss2006's Avatar
    Apr 2006
    That all sounds very familiar, good choices.
    You can solder a little 1/4w resistor and LED to the heatbed instead of the surface mounts
    that will let you know when power is on.
    You can get the heatbed a little cheaper elsewhere but it's a push when you factor shipping costs.
    Make sure you get the double connector for the z on the RAMPS and don't forget
    the SDRamps if you want to run from a MicroSD card.
    SDRAMPS assembled - LulzBot
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Oct 2010
    Cool
    How do you have the steppers hooked up? Ive only ever messed with 4 wire steppers
    Apr 2006
    The ebay motors are 6 wire so they can be used as unipolar or bipolar series if you tape off
    and don't use the center taps (yellow and white wires)
    For the RAMPS with pololu drivers hook up
    red -2B
    blue -2A
    green -1A
    black -1B
    Hoss
    Oct 2010
    thanks.
    just realized there is a 3D printer subforum on here.... oops lots of out of place threads in here now lol
    Apr 2006
    Quote Originally Posted by jeremy0203 View Post
    thanks.
    ehh, threads on these machines under cnc cntrol that sit on a benchtop have more business
    being here than some of the ones on software and the like if you ask me
    Hoss
    Oct 2010
    do you recommend getting some PET tape or kapton?
    i think i may pass on the sd ramps. ill always have my laptop there when printing anyways.
    Apr 2006
    For the hotend?
    I used 1/4 inch kapton tape a number of places like on the hotend for holding the thermistor in place
    and on the heated bed for the same thing.
    1/4 inch wraps nicely around the j-head.
    Also used some 1/2 inch fiberglass tape with PTFE Mcmaster #76495A52 to keep the heat in around the j-head,
    about 3-4 wraps then a couple more wraps of kapton cause the fiberglass tape isn't the stickiest stuff.
    Works great at getting it to and staying at temp.
    Hoss
    1. 3D Printer or X3D Printer
      By mikemill in forum Syil Products
      Last Post: 02-15-2012, 09:41 AM
    2. Converting a laser printer into a 3d laser printer
      By Joćo Carimo in forum General Metal Working Machines
      Last Post: 04-30-2011, 04:56 PM
    3. Should I go for Laser Printer?
      By ethervaughn in forum Printing, Scanners, Vinyl cutting and Plotters
      Last Post: 07-21-2009, 05:25 AM
    4. printer port to usb
      By mocnc in forum DIY CNC Router Table Machines
      Last Post: 03-02-2009, 03:30 AM
    5. Printer for PCB ?
      By WayneHill in forum General Electronics Discussion
      Last Post: 10-05-2005, 01:42 AM
