Here is my first post.
The Chinese Dragon
or try these two..
DXF list Attachments - CNCzone.com-The Largest Machinist Community on the net!
another dxf list Index of /dxf_files
The Chinese Dragon
i spent 2 weeks reading the whole thread from start to fininsh & copied the inturesting addresses into a text file..
you never know when you going to need them..
Here is a SNOOPY HOUSE PUZZLE to add to the collection. Have FUN!
The Gothic House DXF fixed.
enjoy...
Hi, i saw this topic last week and i read all #1366 threads on this topic. But i think i've missed something. I built my cnc router with aluminium body, 3.5Nm 3 stepper motors, 27000 RPM spindle.. now i'm trying to cut some puzzles, but i have some problems.. first one is tool diameter and slot width. I know that when tool is in the center route of toolpath it gives us much wider as tool diameter, and it makes thinner edges same as tool diameter. I want to ask you, is there any software that can creates toolpaths that will follow same drawing but it wont center the tool, just follows the paths with the edge of the tool ? how can you solve this issue guyz by creating offsets ?
Regards,
Serhan
Ola, alguem tem o arquivo do Spinosaurus? "dxf ou dwg"
Hello, anyone have file Spinosaurus? "dxf ou dwg"
http://www.cnczone.com/forums/diy-cn...tml#post828604
"Thread #776"
i am using cambam, finally i've found what im looking for after looking carefully but still have another problem.. i've bought a cutter tool 3mm for MDF cutting, there are two cutter teeth on carbide tool. how can i calculate the spindle RPM and feedrate for cutting 2.5mm, 3mm and 4mm MDF and getting clean results ?
HOLA A TODOS MUY BUEN FORO PERO NECESITO ALGO DE AYUDA, ME GUSTARIA CONSEGUIR EL MOLDE DEL PORTAVIONES Y DE OTROS AVIONES
nadie lo tiene????
VIEJO SI ME DAS TU CORREO TE MANDARE EL DISEÑO
Learning about tooling and all their abilities is one of the hardest parts about cnc machining. no tool will do it all and if your buying tools just because they are cheap then that can be an issue. as for your question about feed and speed. take a look at Onsrud router bit sight and read all you can. I'm not say buy their bits just look at their tool area and read about cutting.
Chiploads | Feeds and Speeds | Metal | Plastic | Composite | | LMT Onsrud
as you try more bits you will find cutting gets easyer.
Erik
Does anyone have a puzzle dxf for a quad cycle? I remember seeing a picture of one but cant for the life of me find it again.
John
John
