It probably depends on how you plan on using it. IF you want to suck through an MDF spoilboard, I'm guessing it's too small. Shopbot sells a 16.9HP regenerative blower for their machines, and big commercial machines use 25-50HP pumps, for the same size table you're using. If you're cutting mostly large parts you can probably get away with less, but with lots of smaller nested parts you'll probably need more. I think the stats you want to look for is how much cfm at a how many inches of Hg. Shopbots is 3" Hg at 140cfm Youmight want to poke around there site and forum for more info.
www.shopbottools.com
