Need Help! Bad tapered ballnose finnishing
Results 1 to 5 of 5
Thread: Bad tapered ballnose finnishing
    Jan 2015
    Default Bad tapered ballnose finnishing
    Hi !
    Can anybody explain me, please, why always my 3d reliefs looks like fluffy ONLY in the left side of model? See photo.
    I used tapered ballnose, 1 mm .
    I tried to change in Artcam raster angle many times but same (traces, fluffy, trails) effect, i also change wood piece pozition vertical and horizontal, a lot of combinations of feeds and speeds.... same bullcake
    What to do? It is possible that my spindle is not perfectly perpendicular to the table?
    Thank you !
    Attached Thumbnails Attached Thumbnails Bad tapered ballnose finnishing-1-jpg
    Feb 2005
    España
    Default Re: Bad tapered ballnose finnishing
    This occurs when the ballnose gets the grain against the grain. I think we all do.The solution, sand.
    Sorry for the bad translation, with an automatic translator.
    Jan 2015
    Gracias! Thank you! But why not happened in both sides? Always in left side and never right side. For example, if i carve a hemisphere, only left side, like a little moon it occurs fluffy.
    Member awerby's Avatar
    Apr 2004
    Different wood species react differently to rotary cutting. What are you using? It's common to get that "fur" on one side of your cuts. Have you tried all-climb, or all-conventional instead of a meandering cut? Sharper tools do this less.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Use a harder wood and cut along the grain.
    UCCNC 2017 Screenset
