Thank you so much for generous help
Here are files I have found searching around for clocks.
happy sawdust makin.
Also here is a larger file for version 2 www.tanasi.com/downloads/ClockV2.zip
thkoutsidthebox
Thanx for the vote of confidence but these are Gary's clock designs among others...give him the credit for the design and me the credit for gleening them for the Zone!!!!
Bob
I will soon test my new MDF machine by following ur clock...
That is my understanding too Mr. Chips....I hope it does these are excellant clock designs. I just happened to find them searching for my wife an anniversary present (PROJECT!!!!!!) and made the downloads to my system for just this possibility....
Bob
{QUOTE
I had been holding off on getting the plans for a clock until I Had my machine done. I just finished and now Gary's site is gone! Does anyone else know of a good site with a bunch of plans? I know of Clayton Boyer's site, but I am looking for more options and Gary had some free plans also.}
I have Gary's 2003 clock pdf's and his dxf file. Brian Law has 4 clocks 0n his site, and is kind enough to let people download dxf files on his clocks if you email him and ask.
Hello!
I have been following this thread with great interest. I wonder if any of you has finished making one? Could you please show some pictures?
I guess cutting all the gears and parts using the .dxf wouldn't be too difficult, but how easy is it to put everything together?
Wachara C.
All the assembly instructions are available on Brian Laws site, here is a short cut to the .pdf file http://www.woodenclocks.co.uk/Clock1.pdf
Tony
I'm reviewing the Brian Law Clock1 plans. I've viewed them in 2D cad too. I have some questions targeted to you folks that have built this clock. Or other smart guys who understand this clock.
1. Part Number 21 is called a yoke, but I can't find any installation view of this part. I don't know where it goes. I suspect it has something to do with the Pendulum drive.
2. The instructions don't detail which parts are glued together, or slip fit.
If anyone knows where Part number 21 goes, please let me know.
here is a mockup of the clock showing the yoke on the back of the clock
Thanks, those pictures did clarify the situation.
There are more on this clock on his website now... Good luck..I built one the old fashion way and never got it to keep time.
Blackbeard52,
any idea, why it wouldn't keep time? I'm also wondering, out all the clocks that are built, how well do they actually keep time.
Actually they do keep time cery well but when I built mine there was not a lot of info on how to build. There are a few forums that deal with wooden clocks. But I havent fooled witth mine in a few years... I have a site that I am going to order from that has a lot of clocks that are funky and hard to buld...I like the challenge...
Bob
Another question for you guys that have built a "clock1". On the Parts List, the item 41 is a "ropering". There are 8 of these parts, but I couldn't find any other reference to this part. No detail part and no assembly illustration either. Anyone know what they are?
On the last page of the instruction sheet you will find a list of those parts that need to be a loose fit, a tight fit and also glued. When I made mine I did find one or two items that were not quite right but common sense prevails.
One thing to watchout for with any clock is friction, ensure that those parts that move are free. One other part to watchout for is the Pawl it needs to be of a close grained wood the grain needs to be orientated correctly. In fact I redesigned mine as the angel was wrong where it intersected the ratchet.
Mine runs perfectly, for just over 11 hours on each wind, and is accurate to around 2 mins over that period.
Anymore questions feel free to ask.
Tony
Tony,
Excellent reminder about the "fits" chart and notes on the last page.
After a quick once over, I thought there should be more glued joints. I might ask some more questions on fits later.
In Note 1, I'm wondering if there is a typo. It says to use "Beech planed down to a thickness of 1 10mm for all components".... I'm wondering why the extra "1" is included? Would that be a typo?
Also since I don't currently have a planer, I'm wondering if using 1/2 (12.5mm) would be ok for all the gears and components. Internal spacing seems generous such that a thickness change should work ok.
Good to hear about the accuracy of your clock. The 11 hour span, makes it more of an ornament then a time piece. I wonder if anyone has gotten more time from a winding? Seems like for every wrap of the drum, you'd get an additional hour. Correct. I'll have to think about that one.
