Wooden Clock Gears - Page 15
Page 15 of 15 FirstFirst ... 512131415
Results 281 to 290 of 290
Thread: Wooden Clock Gears
  1. #281
    Registered DickB's Avatar
    Dec 2011
    Quote Originally Posted by cyclestart View Post
    What are you builders using for the larger cogs ? I have bucket loads of hardwood flooring. Glue pieces together ? Cast acrylic should work well? I don't enjoy cutting MDF.
    I watched the Gearotic video and t looks outstanding but for a first clock buying proven dxf files (g-code files would also be welcome) seems the easy route.
    Baltic birch. Cast acrylic should work well.
  2. #282
    Feb 2011
    Quote Originally Posted by DickB View Post
    I also used JLT's excellent gear designer software (Radial Vector Generator...). .
    BEWARE of the link for the Radial Vector Generator- I tried to download, and it disabled my NIC card!
  3. #283
    Dec 2011
    Strange. I just downloaded it again with no issue. There have been no similar reports on the CarveWright forums.
  4. #284
    Jun 2005
    Hi DickB
    I too have played with the simple two transistor circuits and could not get them working.
    I am very interested is learning more about your microcontroller based impulse circuit.
    From your description I take it that you have a sense circuit to detect the pendulum over the main coil and based on the period of the swing you code will adjust the amount of power to the coil to increase or decrease the impulse to the pendulum.
    Will / could you supply the circuit diagram and HEX files?
    If you would like any help in the design or development of the circuit or the PCB let me know.
    I love the mechanics of a large gear clock except for the fine tuning escapement
    Gareth
  5. #285
    Dec 2011
    Default Pendulum drive
    I would be interested in seeing your project(s) - why not post?
    The circuit itself is pretty simple. I use a single coil for sense and drive. There is a very simple filter on the coil with diode clamps to limit the voltage. This is fed into a TI MSP430 low-power microcontroller's comparator input. The micro has a watch crystal frequency reference and uses it to measure the pendulum period. As you stated, it adjusts the output pulse duration to speed up or slow down the pendulum a fraction. An output port drives a transistor to put current back into the coil. And there is a 3.3v regulator for the micro. I also added a bi-color LED to help set up the pendulum. It flashes red if the pendulum is too slow, and green if too fast. You adjust the pendulum bob accordingly. Once the pendulum is adjusted within the window of close enough for the electronics to manage, the LED stays off.
    I have gotten circuit boards laid out and built by ExpressPCB.
    I've built a total of three clocks now, and they run very well. I have been able to adjust the pendulums in less than 10 minutes using the LED - no waiting for hours or days to see if they are keeping correct time. They keep accurate time after that. I was shooting for a year on 4 D cells, but didn't make it. I calculate 3-4 months. The first clock has been running for a bout 2 months now. We'll see.
    Some videos:
    I just recently finalized the design and made the clock available as a project in the CarveWright PatternDepot. I'm selling a hardware kit of parts, including electronics, for those building the CarveWright project. I'm not putting the electronics and code in the public domain at this time. Contact me through my web site carveshop.com or PM if you would be interested in purchasing the electronics.
    Attached Thumbnails Attached Thumbnails Wooden Clock Gears-s6304849-jpg
  6. #286
    Apr 2007
    Thanks for the info. I know more about batteries than wood gears, so I will comment on that aspect. If you want your clock to run longer, use 4 AA energizer ultimate lithiums. They will go MUCH longer in that application.
    I am not sure if the slightly higher voltage is a factor in your clock though, so you might want to double check that aspect.
  7. #287
    Dec 2011
    Thanks for the tip on batteries. But the AA Energizers you mentioned are specified at 3000-4500 mAh (http://data.energizer.com/PDFs/l91.pdf) while the D alkaline batteries that I use are in the 12000-18000 mAh range, so they will last considerably longer. The lithium batteries have an advantage over the same size alkaline batteries in high-current draw devices, but at low discharge rates (under 25 mA) they have little advantage. My clocks are low discharge rate devices.
    My first clock has been running for over four months on the first set of D cells.
  8. #288
    Apr 2007
    Quote Originally Posted by harryn View Post
    They do last longer in my Sonicare detail sander, plus they last longer for brushing teeth also.
    CarveOne
    http://www.carveonecncwoodcraft.com
  9. #289
    Apr 2007
    Hello DickB - those are impressive cells. I have seen Li, NiMH, and NiCds with those kinds of ratings, but never in conventional D alkalines. What type are they ?
    Harry
  10. #290
    Dec 2011
    They are also Energizer: http://data.energizer.com/PDFs/e95.pdf
Wooden Clock Gears
Wooden Clock Gears
