Wrong type of tool, and too much rpm. Try a 2 flute tool, at 15,000 rpm.
After 10-15 hours, you can expect the tool to be dull, and the diameter smaller due to wear on the cutting edges.
Also, use a blade or bit cleaner on the tool after each use. The burned on build up adds to the heat buildup and dulling. Clean bits will last longer.
