I do not cut to full depth so that the workpiece stays put. I usually make my cutouts using a 1/4 bit last leaving 1/8 depth uncut. This does 2 things.....saves cutting into the spoilboard and secures the part. When finished I cutout the part with a jigsaw or bandsaw then trim the remainder of the edge with a pattern bit on my shaper. Then I sand it smoothe on the stationary belt sander. Tabs work too but they have to be at least 3/16 thick and they take too much time to cut as the zed has to jump around them.
