The all in one, 'how do I' and 'look at this!' thread... - Page 7
Page 7 of 12 FirstFirst ... 45678910 ... LastLast
Results 121 to 140 of 229
Thread: The all in one, 'how do I' and 'look at this!' thread...
  1. #121
    Apr 2007
    Quote Originally Posted by cd_edwards View Post
    Thank you. I'll play around with it this weekend if I dont have to work.
    In the v2.0 file I drew in the closed vector for cutting the bevels with a 90 degree V-bit, but you will have to decide whether you want to use it or not. There are many other ways to make the bevel. 45 degrees isn't a critical angle. When installing the hinges it will be helpful to make a scrap plywood V trough to lay the stand halves into. Lay the hinges in place, mark and drill 1/16" shallow pilot poles and insert a screw in diagonal corners one at a time.
    I didn't think of it last evening because the one I modeled this file after doesn't have them, but we could add rectangles where the hinges mount and create a tool path for 0.020" deep hinge pockets using a 1/8" end mill or router bit. It will help hold the hinge straight while installing the screws.
    Oh yeah, these need some decorations on them while you're at it. Celtic knots of course.
    CarveOne
    http://www.carveonecncwoodcraft.com
  2. #122
    Member LouF's Avatar
    Sep 2011
    Quote Originally Posted by CarveOne View Post
    Here you go Colten. I couldn't locate the original files so I made a new one this evening. It's a medium size stand, so you may need to scale it up for the book and use 1" high hinges.
    I never did cut any of these. Toolpaths can be set up for whatever size end mill or carbide router bit you want to use. I would use a 1/4" solid carbide down spiral. Round the outer edges of the plywood and bevel the hinge edges to about 45 degrees.
    You can draw straight vectors or a rectangle along the hinge edges of the plywood and use them to profile the bevels with a 90 degree V-bit before doing the final shape profile. I plan to do that, but will wait until I am ready to cut a couple of them. The edge view at the bottom of the drawing shows how the shapes are made and how the hinge is installed.
    The .crv and .dxf files are attached in a .zip file.
    Update: Replaced the original file with v2.0 which has better hinge details.
    Thanks for the file C1..
    Lou
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
  3. #123
    Member r00t4rd3d's Avatar
    Mar 2012
    cd can you post the files you have for the book ?
    My CNC Router Build - http://tinyurl.com/c3vs3ca
  4. #124
    Apr 2007
    Someone on the Vectric Forums posted a Purpleheart Medal DXF file that someone else was looking for. I downloaded it for use as more training with 3D modeling in Aspire. Making the rounded shapes was easy. The file was drawn for Vcarve toolpaths. I finally figured out that I would have to split up the vectors so that the ribbon vectors are separated from the heart vectors. This was required in order to "flip" the carvings so they were not inverted. Some of this 3D stuff can get very complicated for the three fully functioning brain cells I still have. I call this fun, but sometimes I'm not so sure about that.
    It still needs some tweaking but it's now mostly a matter of tuning the depths of cut to make it look a little better. I'll cut this into scrap red oak tomorrow to see how it looks carved into a 5" x 7" block.
    CarveOne
  5. #125
    Apr 2007
    I cut the Purple Heart medal today. The vectors around the heart model and the shield area barely left any grooves. I have made the DOC corrections and will cut it sometime tomorrow afternoon when I get the chance. This simulation looks like it will do the job.
    CarveOne
  6. #126
    Member cd_edwards's Avatar
    Sep 2011
    canada
    Right now I'm design computer less. My motherboard on that computer gave up. It's only 3 months old. I'm hoping to get warranty on it. I'm very unimpressed right now with ASUS. Anyways, thursday is payday and I hope to get another board then.. of course all my design files are on that particular computer and I don't want to move that HD to another to get them.. This will teach me to have a backup.
    Colten Edwards [URL="http://www.cncsigns.ca"]http://www.cncsigns.ca[/URL]
  7. #127
    Sep 2011
    My PC is running slow again after reformat and I keep getting Error messages I was thinking about getting something newer..
    Lou
  8. #128
    Apr 2007
    Walmart has Toshiba 500Gb ($59) and 750Gb ($89) USB external hard disk drives that can back up individual files and folders or do a full system backup. The 1TB version is $119. These are fairly quick to backup a computer. I have one of the 500 and 750 versions that I use. I use USB memory sticks for transport from the house to the shop because the wireless N LAN doesn't have a reliable enough signal out there.
    CarveOne
  9. #129
    Registered cdrd03's Avatar
    Mar 2006
    Thats a great idea C1. I have a western digital 500gb that I back all my cnc stuff on up on.
    Lou when you up grade your system make sure your software is compatible with the new os. I don't know how different Windows 8 is.
    Chuck
  10. #130
    Sep 2011
    canada
    Yeah I've got a 1tb drive. Just need to remember to use it. I tried wireless out to my shop but it didn't work very well. So I sucked it up and used the cat5e cable that I had run from the house to the garage when I put in the power but had never gotten around to using
  11. #131
    Apr 2007
    Quote Originally Posted by cdrd03 View Post
    Chuck
    The one person I know that has installed Win 8 said yesterday that he does not like the new interface and uninstalled it after a week of trying to figure it out. He is a long time computer repair person who generally has little trouble figuring out the new releases of Windows.
    I purchased two OEM copies when TigerDirect had them on sale for $20 off each copy right after it was released. They have not been installed on anything yet. If it cannot be switched to the older style interface (like previous versions allowed) they may not ever get installed by me. I will have to get more opinions about the new interface before I bother with installing them to see what it won't run. I quit long ago attempting to be the bleeding edge techie and the first on my street to have the latest M$ operating system at home.
    I have read that the Vectric software runs ok on Win 8. That isn't all that needs to run ok on it though.
    CarveOne
  12. #132
    Sep 2011
    Chuck
    Chuck thanks, I run XP Proffersional on my shop PC I have contacted Dell and HP and tried to order a XP machine they don't sell them any more will Mach3 and Vetric software run on Vista or windows 7 or 8?
    I wonder if I buy a new hard drive and install it and use XP I don't know much about that I have been using a memory stick like C1 said to get since my last PC nightmare..
    Lou
  13. #133
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    It's $5, but this is supposed to be the best option for a Windows 8 Start menu
    Start8 for Windows® 8 - Bringing back the Windows Start menu
    There are other options from other developers.
    Haven't tried any, as I'm still using XP.
    UCCNC 2017 Screenset
  14. #134
    Sep 2011
    canada
    I run Mach3 under Win7 pro. I also run Aspire on Win7. So yes it will work fine.. just remember to turn alot of stuff off.
  15. #135
    Apr 2007
    Thanks Gerry. I use XP Pro on the CNC machine computers and Win 7 Home edition in the house for project development. One other computer runs Win 7 Pro 64 bit.
    I bookmarked the site for when I add Win 8 to something.
    CarveOne
  16. #136
    Mar 2003
    Shelby Township
    I use Windows 7 Pro x64 at work, and I like it a lot. I'll be finally upgrading later this year when the next gen Intel processors come out. So I have a few months to decide whether to go with 7 or 8.
  17. #137
    Sep 2011
    So windows 7 will work I have looked at a few there mainly 64 bit and have no Parallel port how do you get around this?
    Lou
  18. #138
    Mar 2003
    Shelby Township
    You need to use a 32 bit version of Windows 7 if you want to use the parallel port.
    Otherwise, you need to use an external motion device like the Smoothstepper.
  19. #139
    Sep 2011
    Thank you Gerry.
    Lou
  20. #140
    Apr 2007
    Quote Originally Posted by ger21 View Post
    Will a parallel port plug-in card not work with the 64 bit OS? The card slots should still be 32bit interfaces.
    CarveOne
