Where can I find resin impregnated laminated wood
Results 1 to 17 of 17
Thread: Where can I find resin impregnated laminated wood
    Apr 2003
    Ohio, USA
    Default Where can I find resin impregnated laminated wood
    Comes in stained and multi-colored, You have seen it on knife handles, pistol grips etc.
    max size needed is approx 3" X 4" X .5
    Ken
    Dec 2003
    Is this a one-shot deal? how many layers do you need at .5"? If it is a one-off you could get some hardwood offcuts and make it up. I have used clear epoxy paint for impregnating.
    Apr 2003
    Ohio, USA
    Hi Al,
    I would be needing it in small quantities of 30-50, the Layers need to be pretty thin for better detail, I am guessing but I suspect that they are 1/16 in thickness or so.
    How did you use the clear epoxy for impregnating.
    Ken
    Community Moderator ynneb's Avatar
    Feb 2004
    Oz
    If you have access to a vacuum chamber (sure, I carry a spare one all the time) you could emerese the wood in 2pack resin, pull out all the air pockets from the timber under vacuum, relese the vac and the timber will pull in the resin. Just make sure the 2pack resin doesnt go off too quick.
    I have never done this b4, just an idea.
    I am sure it would be easier to find a supplier of the stuff though. Good luck with your search
    Being outside the square !!!
    Apr 2003
    Ohio, USA
    LOL
    I was wondering how they do that and I bet you are pretty close, unfortunately, too time consuming. I have looked and just cannot find this item, except from a exporter in Pakistan, but that requires a financial involvement that I am not willing to take at this time. It's use is very common, I would think it would not be all that difficult to locate but no success so far.
    Thanks Benny
    Ken
    Dec 2003
    Quote Originally Posted by Ken_Shea
    I just immersed the item in the clear epoxy paint to soak well into the wood and after removal, brush stroked the excess off.
    Al
    Jun 2003
    Boalsburg PA
    There are a couple of magazines dedicated to knifemaking. Blade is one I remember. Seems like this should be available from there. Luthiers do this sort of thing all the time absent the epoxy. I would think many knife makers make their own as well.
  8. #8
    Gold Member
    Jun 2003
    Ken what color do you want it in or do you want multi color? I have several,
    wel ok maybe 4 or 5 different colors including a natural oak that I use in my pistol grip production. You do know how expensive this stuff is.....................
    don't you?
    Mike
    ps I suppose I could tell you that I have burgandy, cocobolo which is a beautiful burnt orange, black, the oak and I think I still have some multicolor pieces but not as many.
    No greater love can a man have than this, that he give his life for a friend.
  9. #9
    Feb 2004
    Oz
    Ken, you got me wondering.
    I found a possible supplier for you. http://www.ckcomposites.com/wood.html
    Oh and yes I see vacuum does come into the process.
    EDIT: try here too http://www.insulam.com/
    and http://www.permali.com/english/framset_permali_en.htm
    Possibly this one too http://www.rutply.com/sbond.htm
  10. #10
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    UCCNC 2017 Screenset
  11. #11
    Apr 2003
    Ohio, USA
    Thanks Unterhaus, I did find some suitable in size for knifes but not large enough for grips.
    Mike (Turmite), colors would not be specific but mostly wood colors such as you have mentioned and perhaps the multi color. You are making me nervous now no, I don't know how expensive that is.
    Let me think, where Pakistan is now
    Benny, Ger21, I will check all the links, thanks for finding them, I found only one relevant site.
  12. #12
    Gold Member
    Mar 2005
    Also, check out:
    http://www.fibronproducts.com/
    -Jeff
  13. #13
    Gold Member
    Jun 2003
    Ken the material I have is not made in Pakistan. It is good ole USA stuff. It was originally made by a company in Mass. called Adams Pakkawood but is now made by Rutland Plywood of Rutland Vermont. I don't have a url but it should not be hard to find. I have quite a bit of this if you are interested and I promise the price will be less than if you buy it direct.
    Mike
    ps if you are interested send me a email at my website
    www.turnercustoms.com
    Be sure and include your name!
    Don't answer back on the request for addition to my address book. I will get the mail.
  14. #14
    Member Kool Parts's Avatar
    Jan 2004
    Ken_Shea
    Give Bill a call, he might sell drop offs that would be big enough for you. They go though a lot of wood year round. In every color combo you can think of. He is a distrbutor of Rutlan Ply wood. I make some of his metal parts.
    http://www.scopeusout.com/
    Gary
  15. #15
    Gold Member
    Jun 2003
    Hi Gary,
    I am not 100% sure but I think that Bill uses the colored, but not the resin impregnated material. He also uses a laminate from Italy that is about as wild as anything I have ever seen.
    Mike
  16. #16
    Gold Member
    Apr 2004
    I buy all mine from a real nice fellow in Arizona. He has some really nice stuff, you should check him out.
    .arizonasilhouette.
    Most of his sells are for pen makers but he has some really nice blocks of "eye candy" that are perfect for knife scales.
    I have turned some duck call with this stuff and they turned out great.
    Give him a call, his name is Bill.
    Hope this helps
    Chuck
    Aspire, VCPro, PhotoVCarve, Cut3D, Mach3, Home built CnC.
  17. #17
    Apr 2003
    Ohio, USA
    Gorgeous stuff Chuck, but too fancy (read expensive) for my intended market, I did save the link though for future considerations.
    Ken
