Your more likely to break them by going to slow than going too fast.
The 175ipm is probably a decent number, but you can go much faster in poplar. However, faster feedrates can reduce cut quality. I often cut poplar at 300-350ipm @ 18,000 rpm, with about 1/8" depth/pass. I cut shallower to get better cut quality.
Make sure the wood is mounted securely, as a loose workpiece is the quickest way to break a bit.
