Absolutely not. But a good dust collection system may preclude the need for an enclosure.I'm wondering if the enclosure by itself would preclude needing a high-power dust-vac system when running.
Cutting without dust collection would literally fill every inch of your enclosure with a layer of dust. A good dust collection system will catch almost all airborne dust.
A folding table is not realistic.Space saving. (I've either gotta be able to stow this thing or use it as a work bench when I'm not cutting. So my thoughts are folding table style frame, or mount the CNC pretty-much on the floor and build a work-table directly on top of the machine so I can rivet wings or weld fuselage while its cutting away my happy parts.)
As for building a workbench on top, keep in mind that a 4x8 cutting area machine will be at least 5'x9', so a removable top might be large, and rather awkward.
You may find it possible to work right on the machine bed itself.
Nothing, other than a method of holding the blocks down.What would be needed beyond what I listed above, to use a machine like this for 3D milling of nylon blocks?No, there's no reason. Plenty of people are making plastic parts with CNC routers. Just be aware that not all plastics are easy to machine.
Is there are reason almost all 3D work I see on youtube is in wood and foam and not in acrylic or nylon?
Depends on the part, but should almost always be much faster than a 3D printed part. Unless the parts are very complex.But are the turnaround times for a decently finish-passed 3D part any better on these types of machines?
I'm not really sure what you're asking for here?I know that it comes to speeds and feeds but, imagine that I'm going with relatively budget drivers and a cheap spindle or router... what are my realistic options?
There's a member on the MechMate forum that recently built a Mechmate specifically for building airplanes, and cutting aluminum sheets.
I'd probably recommend a Mechmate or CNC Router parts machine. What's you're budget? You should probably expect to spend somewhere in the $5000-$7000 range.
