Originally Posted by
ACETRENB
so you use the pin to do the fixture ok that part i got it, so where do you set your home position in the drawing, because the way i see, i can use the middle of the stock as a home position so when i am gonna make the part in solidworks the origin must be centered in the piece, or i can use the edges of the stock as home position and when drawing in solidworks i must calculate where the y and x homes will be to use the stock edge as home position and the center of the part and the center of the stock will be aligned
