I this on a Burny or similar plasma machine?
It could ESSI, but it has been a while since I have used it.
A search for ESSI programming may bring something up.
Hi, I was just looking fo some help and education on the bellow code. I was told it was SE code, but I would like to confirm this. Also, is this metric or imperial inch? Second concern I have is where do I assume the decimal goes?
Thanks for any help with this!
81
502
+0+0
503
500
86+0-84815
+101792-84815
+101792+98666
+101792+98666
+67923+98666
+67923+69864
+49271+69864
+49271+41328
+28415+41328
+28202-33875
+1626-33878
+1626-33878
+0-84815
88
501
502
503
pronouncing 'essi' sure sounds like 'S-E' ...
sam
hi,
anyone has the PDF manual for programming ESSI format.?
I need to learn good all code for CNC plsma cutting machines, in particular: esab cutting system suprarex SXE-P5000
thanks!
Did you try Google???
This showed up section 4!
http://www.practicad.com/docs/burny1400manual.pdf
The code is indeed essi. Very common in plasma, oxyfuel or laser cutting machines.
Angelo, did you get your machine from Esab? If so then they should have supplied you with an essi programming manual. I have a couple of them at work if you need particular info from the book. I can look but I'm not back to the dark side until Jan5th.
Is your machine plasma only or with oxyfuel and does it have a bevelling head?
the manual is probably in some company office. Anyway I was interested in deepening knowledge of the machine from home in order to understand in detail the usefulness of all the codes and the reason why they are activated.
the machine esab cutting system suprarex SXE-P5000 1990 is only plasma cutting. I tried searching on google but could not find anything. I will try to last to ask the user to esab. thank you all
Hi I used to program and run an Esab flame cutting machine, it used Essi code generated by my nesting software (Lantek) I could possibly do you some sample progs with dxfs to compare.
Mark
If in doubt ask!
