Hi Benergyi have cut stainless recently and after much cutting of normal steel am frustrated by the quality of stainless cut. is it customary to have black jagged finish?
Have you tried all the things I have done above?
You will find that Stanless just does not cut as nice as mild steel.
My machine will cut mild steel very close to a Laser finish.
But Stainless is still very hit or miss.
Everything has to be set perfect to get a pefect cut.
Clean dry Air, good consumables, correct cutting heght, correct speed etc etc
If anyone of these is not 100% it will affect the cut quality.
Hi LowpullHow about making a new lightweight gantry and put it on the table at the same time as the other gantry. Just move the gantry you are not going to be using to the very end of the machine, move your connections to the other gantry that was stored at the other end of the table and voila. I am sure that there are other issues involved but its just an idea.
Thats a good idea, but my Bed is only 1 metre long, so I would lose a lot of cutting area
I am planning on making a Version 2 machine over the Winter if funds allow
It will a Plasma specific machine, and it will have a bed size to take a stock 2000mm x 1000mm Sheet.
That will save me loads of time having to cut sheets down all the time!
Andy
