flying bridge flojet running FLOCUT 6 error message
Results 1 to 3 of 3
Thread: flying bridge flojet running FLOCUT 6 error message
    Feb 2007
    Default flying bridge flojet running FLOCUT 6 error message
    I'm looking for guidance on tracking down the cause of this error message M-13=0 Estop Overtravel ABZ .
    I'm resetting a machine i bought used and transported across the country. It was operating just before disassembly.
    I have double checked the connections.
    The AB axis is the curf adjusting head tilt. There are four prox sensors
    two labeled homing and two lableled travel. Does anyone know how to determine if they should be nc or no and under what conditions they should switch?
    Guy
    Aug 2010
    uk
    Quote Originally Posted by GUIDOSAN View Post
    Guy
    The top switches are the overtravel and are N.C,there triggered when the dynamics head goes over 8 degrees.
    Don't know if you're aware but if you push in the lower green button on the side of the screen hold it and then push and hold in the top at the same time it should bypass any overtravel.
    Feb 2007
    Default Re: flying bridge flojet running FLOCUT 6 error message
    Quote Originally Posted by adambrum View Post
    Thank you - that helps and i'll try the bypass.
    Guy
