Anyone tried making a DIY Water jet cnc?
Results 1 to 10 of 10
Thread: Anyone tried making a DIY Water jet cnc?
    Jan 2011
    Norway
    Default Anyone tried making a DIY Water jet cnc?
    Hi guys, i have looked, searched and google my way through the forums and i cant find anyone trying to build their own DIY water jet cnc machine.
    Do any of you have experiences with this?
    Is it to hard to pull of as a hobby? To expensive?
    Wonder how rigid the cnc would need to be built for water jet cutting. It seems that Hiwin rails are more or less standard when it comes to rigid cnc mills and routers, but i wonder if its possible to use cheaper rails since it is no direct milling going on.
    Feel free to comment or post links if you know of any.
    Jan 2011
    Norway
    Default Re: Anyone tried making a DIY Water jet cnc?
    found a good tread. http://www.cnczone.com/forums/genera...526-cnc-6.html
    looks like the cost and safety is the main killerr for a diy water jet?
    May 2006
    100,000 psi, diamond nozzles, pressure pumps, slurry tanks, bags of expensive grit
    don't bother,
    But do you have work for it?
    Rent one. these are dangerous
    (I've done 5axis WaterJets)
    Been doing this too long
    Jan 2011
    Norway
    Sounds like im back to the drawing board on an aluminium cutting cnc mill again.. its hard to find some proper plans for a steel built cnc in the 4x8feet or a little bit smaller type
    May 2014
    The thing is, you need to design and build the intensifier pump. It's only unsafe if you build it that way. Many people likely would build it unsafe or failure prone. Everything else can be bought off a shelf or welded together more or less. It's that pump and all that goes with it that cost all the money.
    Sep 2005
    Indonesia
    I read on this zone that chinese made is around 25k Catalog,
    but if you want to buy wardkit jet starting from 70k to 90k. https://wardjet.com/products/waterjets/wardkit
    If you want DIY maybe try chinese made.
  7. #7
    Mar 2012
    There is a low cost waterjet on Kickstarter called Wazer or about $4,000. It can't cut 1" steel, but it is still fairly impressive.
    https://www.kickstarter.com/projects...aterjet-cutter
  8. #8
    Member dharmic's Avatar
    May 2015
    0.4 ipm for 3/16" mild steel.
    I appreciate they've had to make some sacrifices to keep the cost under $25k, but still - at that speed then for anything bigger or more intricate than a credit card sized rectangle I'd have time to take my stock and drawing across town to a commercial laser/jet place, let them do the CAM program and run ten then bring it all home before the wazer had finished the first part!
  9. #9
    Sep 2005
    Indonesia
    Yes, dharmic, you are right...
  10. #10
    Sep 2005
    Indonesia
    Can we use mach3 or uccnc/cncdrive for water jet?
