Machine: make, model?
Material: type, thickness, state?
Mode of failure: won't cut with low pressure, won't switch to low pressure, etc.?
Please provide more information ...
is there anyone know the solution why the Low Pressure is not working?..
- Conquest almost working - no hydraulic pressure
- What is the difference between wood working and metal working routers?
- Switch view between machine working enveloppe and job not working?
- Need Help!- Leblond / Fanuc OM Lube Pressure No 2050 Oil Pressure Alarm
- Problem- SteelTailor plasma power source stop working because of low air pressure how to do?
it's a waterjet cutting machine from cms technocut, it's a 2005 model..the problem that I'm dealing now is that emulsified oil and the low pressure is not working when I'd switched from high pressure to low..any idea what might be the cause of the problem?.
@KilrB thanks for your reply Sir
Machine name is: Tecnocut made 2004
Material: all types of steel, marbles or tiles or wood and cardboard up to 200 mm thickness
Mode of failure: low pressure is not functioning
emulsified oil? As in hydraulic oil and water mixed?
Yes Sir, the water is mixing with oil
can you send your machine picture ?
