I have built Henry Washburn's EDM from Strictly IC magazine. The setup uses a stepper and 48 volts 5 amps for the probe. Everything is adjustable including the timing for the stepper and probe. I use it for getting those pesky little broken taps and stainless parts out of alum. normally in the 4/40 size. I don't have the plans or schematic as when I was in touch with Henry they where copyrighted and would not violate his work.
The problem with mine is on the larger items where more power would help out. For fluid I use de-ionised water with a coffee filter for straining. Never have seen anything in the filter so the crap probably lays in the bottom which I clean after use. It also is very slow cutting but I have lots of time especially when I look at remaking some of my turbine parts. I also use a windshield washer pump but am going to find something that will run continuous as it heats up. You need something with a bit of pressure to blow the metal out of the hole or it will start to arc all over the inside.
I will include a picture of mine from an old drill press that went up in smoke in a fire. I may be able to help in some ways.
John
