I would try to buy from sellers with ratings over 98.5%. They also have not sold many of them on ebay. Support would be a problem I think. Try torcheads site. http://www.candcnc.com/ At least you can harass him here on the zone.
WSS
http://cgi.ebay.com/3Axis-Nema-34-St...ht_3601wt_1139 and
http://cgi.ebay.com/4Axis-Nema-34-St...ht_3144wt_1139
Looking at buying one of them, but prices seem too good to be true. Any opinions? Chinese stuff, but would it work?
WSS
I can tell you this kit is not compatible.
1: 24V power supply is too low for this motor
2: The Motor has low current but very high Inductance.
3: The total cost is more than $500 ($385.90 + $125.90)
check here
http://www.kelinginc.net/CNCPackage.html
David
Dang. Well I need a custom kit, and am running something like 4:1, will it be able to mill aluminum at 380oz? it doesnt need to be fast. Also someone had a link somewhere to a 12ft rack for 80 dollars?
Thanks in advance.
wait, by the way, nema 23 can do 570oz?
http://cgi.ebay.com/3-Axis-Stepper-M...#ht_779wt_1137
I recently bought one of these kits and it has no documentation. If anyone out there has this kit up and running with Mach3 please take a look at the schematic link and let me know about any wiring problems you can spot, thanks!
The machine breakout board has a green LED lit and the motor driver has a red LED lit (think this is where the problem is).
ImageShack® - Online Photo and Video Hosting
I believe the following are problems.
Your pulse and direction signals should be to the negative terminals on the drivers from the BOB
Feed +5v to the positive terminals of the step and direction of the drivers
Enable - isn't usually required
Enable + should be 5v
The only 24v you need is to the DC pwr and ground on the driver.
Please wait for someone else to confirm before making the changes.
Hello, everyone, i am Mary Chen from Longs Motor, this is our company official ebay store: Longs Motor Co Ltd items - Get great deals on CNC Router, Hybrid Stepper Motor items on eBay Stores!. For our company website, that is Stepper Motor/Stepper Gearmotor/Stepper Motor Driver wholesaler and supplier.
I just checked talkers said that didnt get the instructions. Usually for manuals and instruction, we usually sent them by electrical files, which is more convininent. So when you received the packages and didnt know how to wire, you can contact us, and we will send them one by one.
After you read these manuals and still dont know how to wire, you can also email to us (mary@longs-motor.com), we will helo you in technique.
In addition, if anyone who has some questions about our company products or using, you can leave messges to me in ebay or CNCzone or mary@longs-motor.com.
Mary
Thank you so much for your input. I was able to replace the dead on arrival kit power supply, and I hooked up the kit with the break out board power by a separate 5V supply.
As soon as I connected the parallel port, the Break out board LED would go dim. - I was unable to get the motors to move using Mach3 V2.0 - Does this kit require a config file?
I also tried using the break out board without the external 5V power supply. JP1 and JP2 are in place, but the Green LED is not lit. (Is the board broken?)
Again I was unable to get the motors to move using Mach3 V2.0 - Does this kit require a config file? Should I try replacing the break out board?
Hello, dear madam or sir,
Our ebay store has some update. That is the newest one:
CNC Router, Hybrid Stepper Motor items in Changzhou Longs Motor Co Ltd store on eBay!
If anyone has questions about our company products, please feel free to contact me. My email address " mary@longs-motor.com"
Best regards
Mary Chen
Best regards
Mary Chen
WWW.LONGS-MOTOR.COM
I buy a kit from them on ebay last year and now I am trying to set it up but there is no info and they send me a very very bad drawing of the wiring I try different wirings and still no response from mach3
I got a 3 axis nema setup from longs-motor.. I just received the wiring diagram as well.. It makes sense.. It doesnt seem too complicated, It just refers to needing an additional 5vdc/2A power supply for the breakout board.
This is Cherry from Longs Motor,Could you tell us which the kit did you order?
If you have any questions,please send email to cherry@longs-motor.com
Reagrds
Cherry
This is Cherry from Longs Motor.
You dont need to order additional power +5V for the board,the detailed info we can send to your email,so please send your confuse to cherry@longs-motor.com
Regards
Cherry
Regards
Cherry
This is Cherry from Longs mtor.
If you have any questions,please send email tocherry@longs-motor.com or add skype: chenpeijuan2010
more items you can view our ebay & aliexpress stores
longs_motor on eBay
steppe motor/driver/cnc kit/3D printer
Reagrds
Cherry
You dont need to order additional power +5V for the board,the detailed info we can send to your email,so please send your confuses to cherry@longs-motor.com
Regards
Cherry
Yes you do. Ihave the 3 x nema34 with 3 x 60v power supply units. There is no other way of powering the breakout board which comes with it (DB25a) unlss you use an additional power supply. This was also instructed by Mary @ longs motor.
The wiring for these units uses the negative as the driver for pulse step and direction. So you combine the positives as a constant power and connect the -5vdc from the breakout board to the stepper drivers. (EG: pin 1 goes to negative step on the driver ) this is within the documentation I received from longs motor.
Anyway fellow forum users.. The support for these things are in very broken English and can be hard to explain but my units have the accuracy and repeatability down to 0.01mm / 10 microns using chinese ballscrews and I have no problem with them so far and even in direct drive without pulleys, they have enough power to stall a 1kw motor.
here is a demo and also my settings using LinuxCNC
I hope this helps...
I bought a kit from them a year ago, one drive was not working. Sent them a few e-mails, they never got back to me. I assume that support also non-existent.
