You need CAM software.. ArtCAM as an example will do bitmaps.
Even if you would find some g-code, it might be for a different tool & wrong dimensions.
Hub
I'm new to the CNC world. I'm having a problem finding a g code for a eagle. I would like to engrave it into a raised panel door. The door is a standard 3/4" thickness. Any help would be appreciated. I'm looking for something like this. If possible one code facing left and one code facing right. Thanks!!
Hub
:) Current build: http://www.cnczone.com/forums/diy-cnc-router-table-machines/264838-new-machine-desing-quot-cnm13-quot.html
