Best mask
Results 1 to 3 of 3
Thread: Best mask
    Aug 2014
    Default Best mask
    Can someone recommend a good all around mask? Most projects will be smooth.
    need something that will stay in place while cutting and not pull the finish off with it.
    Stuff I have tried hasn't worked.
    May 2009
    Default Re: Best mask
    I have been using sign vinyl for quite some time. It's the same vinyl that is used by graphic shops on their plotters to cut decals and signs for cars/trucks and comes on a roll. It works great and does not peel if applied to a dry, clean and cured surface. The key is to ensure you finish is fully cured. The only caveat is that it sticks really well, I use a hair dryer to warm up the adhesive and pull it off slowly. So far it's the best mask I've used and I tried many of the commercial products out there. Hope this helps!
    Nov 2010
    I have been using Oramask 813 for years, and has never let me down.
    Mike Kearns
    www.noveltysigncarver.com
Best mask
Best mask
