Specific tech name for adjustable coolant pipes?
Results 1 to 4 of 4
Thread: Specific tech name for adjustable coolant pipes?
    Mar 2011
    Question Specific tech name for adjustable coolant pipes?
    What is the specific technical name for the adjustable coolant pipe that is assembled from a stack of small plastic cones/spheres?
    I want to get a big diameter one, for vacuuming near the cutterhead, say 1 inch or 2.5 cm in diameter.
    Does such a thing even exist?
    Since I don't know the name of it, I don't know how to find it on the web. My Google-fu fails me.
    Apr 2013
    Sweden
    Default Re: Specific tech name for adjustable coolant pipes?
    Flexible machine coolant pipe
    Specific tech name for adjustable coolant pipes?-flexible-coolant-pipe-jpg
    You mean that? I don't know if you can find those at that diameter and I also doubt it would be efficient enough with just a naked pipe end, but perhaps I am wrong.
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by DMahalko View Post
    It's name is Loc-Line, there is some other names Snap-Loc, Loc-Line was the original manufacture, I think 3/4" is the largest size
    Mactec54
    Mar 2011
    Thank you, that is exactly what I needed to know.
    1/4", 1/2", 3/4"... then it jumps up to 2.5" for fixed position vacuum hoses.
    modularhose.com - Loc-Line 2.5" ID System
    Which I've never seen before, and I must say is hilariously huge.
