tool radius in dadimac may be to thick for those corners for bworks to calculate
Hello, i made a dxf in autocad to import intro the native cnc biesse cam biesseworks for machineing, but when i import it and
add machining process, the tooling correction is on different sides some are on the left, some on the
right, and i am not able to correct it, as is imported as single geometry only as a as a single unit . Can someone tell me how to make the neccesary fixes
before exporting the dxf. Thank you
I attached a video and a photo of my problem. Anyone knows how to fix this issue. Thank you .
