- New member from Birmingham
Hi.
I am Coly, from UK.
I am starting to do my 4 axis CNC router and I found this forum with a lot of useful information.
My CNC it is small, 150x250x100mm working superfice and I will use for engraving in brass, silver.
I am lucking for the maximum rigidity and precision, not to speed.
I am in the middle of the mechanical construction.
I am planing to use samsung 200w servomotors, THK 2mm lead ballscrews and Teknomotor hf 0,27KW, 24000Rpm as spindle.
Is not clear if I will use CPU5B for my 4 axis (starting with 3 first).
Coly
- You may not post replies
- You may not edit your posts
Forum Rules
