Different Dimention
Results 1 to 5 of 5
Thread: Different Dimention
    Sep 2017
    New Zealand
    Default Different Dimention
    hi all
    I have a problem with my diy cnc. I have to going right as it move OK and calibrated right i am use mm. my cutting size is X=350mm Y=400mm and using mach 3 demo
    .My problem is that when i want to move 50mm i have to type in .50mm and when i want to move 100mm i have to type 1. ect
    When I did my sketch in fusion 360 i did it all in mm eg 50mm /50mm sq but when i put it into mach3 it wouldn't cut right
    As I can see i have done everything right i zero it all right, i put the cnc in the middle of the table zero it there and then line the sketch there i but when i go to cut the sq it goes to the edge of the cnc machine and try to keep going.
    It seem to my the decimal point is in the wrong place
    so i hope some can help
    Sep 2017
    Default Re: Different Dimention
    Is there a steps per mm setting that could be set wrong I don’t know because i have never used mach 3
    Sep 2017
    New Zealand
    thanks for replying i will have to check but would see anything
    Member awerby's Avatar
    Apr 2004
    In Config/motor tuning you'll see a steps per unit setting. Try increasing the number of steps by a factor of ten, and see if things are closer to right. The issue with zeroing is probably a mismatch between the origin set in your CAD model and the zero points you're setting on your machine - they should be the same.
    Sep 2017
    New Zealand
    hi thanks
    I tried what you said but it didn't work . not sure what to do now
    i increased the number of step by 10 and when i to I type in 50 and the machine went right across to the other side of the table
    i using a axis calibrate in the setting window. do you have any other idea
Different   Dimention
Different   Dimention
