- North America Okuma MA-600HB Z Axix Problem
Hi everyone,
We have an Okuma Horizontal Machining Center MA 600H
We have a problem when we machining 3d Part, Our Z Axis is not stable , we have a not good finish , its look like the drive have hard time to process all the data from the different encoder, is there a way in some parameter to tune the setting of how to process encoder or just disable the scale encoder , to be sure that the problem came from the encoder or the cable encoder, all other axis works fine and are accurate.
Thanks for your future advice
Regards
- You may not post replies
- You may not edit your posts
Forum Rules
