Came into posession of aVFD and a 3 ph motor, want to try running it.
VFD is Siemens Micromaster 420 (240v input, 3kW motor max).
Wired it to single phase mains, it starts up fine.
Motor i want to connect is 3ph ac motor from gym treadmill.
Plate: https://i.imgur.com/1y3qxF2.jpg
What i need to know is how to set parameters for motor i have here.
I will be wiring an off/run/reverse and speed pot later on.
General idea is to fit it into belt grinder i'm making for my shop.
Anyone here with experience in siemens VFDs ?
P.S. I have RS485/usb adapter to connect it to pc for config, but not quite sure how to do it. Any help appreciated.
Mactec54
Hm. Correct me if i'm wrong.
I dont think its BLDC. No magnets. Also, on shorting phases and rotating it does not brake.
The plate probably refers to controller because of starting current of full line might be a bit much. Hence no HZ rating.
Treadmill it came from was an "industrial" type, not home machine. Think proper gym treadmill (LifeFitness 9500HR).
I use BLDC motors in my RC stuff, but all of them have permanent magnets.
Excerpt from LifeFitness 9500HR service manual, chapter on controller board that runs this motor:
Functional Description
The Motor Controller PCB is a single phase AC input PWM variable frequency three(3)
phase AC output motor controller. Specifically the controller input is configured as a
full wave bridge for 230volt AC input, and as a voltage doubler for 120 volt AC input.
The resultant DC bus voltage is processed through a microprocessor controlled six
switch DC to AC inverter. The output is three phase power with pulse width modulation
of both voltage and frequency.
It sounds like your more or less normal VFD, but with treadmillish bells and whistles.
Actual board: https://i.imgur.com/UK1jDg0.jpg
Theres some big, ceramic looking components on the back screwed to big heatsink, cant photograph it without taking that off. There is rectangular dashed line marking position of that white (ceramic?) component.
I have all the electronics pulled from working machine, but using it as is makes it a bit cumbersome due to "smart" functions. Theres IR proximity sensors, wireless NFC like reader (for wireless heart rate monitor chest straps), incline motor and limit switches, logic/display/user input board, magnetic stop, emergency stop. ALL of that has to be connected and responding in order for motor to run. Otherwise internal diagnostics halt booting procedure with some fail codes.
Yes it sounds like you could run it from a normal VFD, except for one thing, the normal VFD is only controlling Frequency, that is why it is called a Variable Frequency Drive you need it to control Voltage and Frequency with PWM control
There is another problem, to use a normal VFD you need to set Parameters related to the motors Frequency, so you would need to know what the motor's minimum and max frequency is
Mactec54
