Hello there, I'm having a little trouble with the Nc Studio 5.5.6. I made a printed circuit board to test it, then a made it in g-code and loaded to Nc studio, the problem is when I simulated and when I cut it on my CNC; the problem is that it doesn't respect the length on the X axis when I simulated and when I made it with the CNC, the circuit should be around 5 cm x 5 cm but it extend it to 5 cm x 10 cm.
I double checked my g-code using another software and its fine.
I don't know what might be the problem so I hope you could help me. I leave you my code if you want to check it out.
