diagram of mitutoyo linear scale model AT112-one side is 9 pins?
Results 1 to 3 of 3
Thread: diagram of mitutoyo linear scale model AT112-one side is 9 pins?
    Nov 2016
    Netherlands
    Default diagram of mitutoyo linear scale model AT112-one side is 9 pins?
    does anyone have a diagram of Mitutoyo linear scale model AT112 using a 9 pins round plug?
    I need to match it to a KS series DRO that uses a 15 pin RS232 type connector
    It is very difficult to find àny information on these connectors: it would be a great great help if I would know the +5V Vss and the color of the Ground wires because the other two signals can be determined using an osciloscope
    The connector has the following colors:
    red
    orange
    yellow
    blue
    green
    brown
    Normally the +5V is red and the grnd black but there is only a brown colored wire
    again any help is greatly appriciated
    thanks!
    Nov 2016
    Netherlands
    Default Re: diagram of mitutoyo linear scale model AT112-one side is 9 pins?
    sorry it is not a 9 but a 8 pin connector like this :
    Attached Thumbnails Attached Thumbnails diagram of mitutoyo linear scale model AT112-one side is 9 pins?-mitutoyo-linear-scale_1-jpg
    Jun 2005
    Look for the manual for their reader it will list the pins and signal names
    Russ
    Jun 2007
    Quote Originally Posted by SparkyNL View Post
    Did you ever figure this out?
    Riyonmein's Avatar
    Aug 2020
    Search for the manual for their peruser it will list the pins and sign names
